Buying Advice what do i need
   / what do i need #1
nomoney
somewhere, ks
jd ihc
Hello. Well I am getting back in the hay business
and need to get a different tractor. I want
something that can handle a jd. 336 baler
and can handle a farmhand f11 loader.
of course anything can handle a mower
and rake. I'd also like something that
Could pull a 16x8 drill.
An m is too old, I had a 460 and its shot.
Want something a pinch newer but
Don't want to go crazy.
Would like a 706 but hard to find a good one.
would consider a green, red or orange one.
Thanks for the input.
   / what do i need #2
Welcome to TBN. Only need about 35hp @ pto for the 336. Need a bit more than that for the drill and mower (if it's a disc or say, 9 ft. sickle). So, that's leaves you with a really big playing field!!
Lotta IH iron in Kansas. Used to feed cows with both an 806 and 560 gasser's. Had a Farmhand on the 560. Never did like that tri-cycle gear, though. Could hardly steer the darn thing once the ground was even a bit muddy or had a skiff of snow on it!
Your budget is one of the biggest factors in what you buy... and what you'd like to own.
AKfish
   / what do i need #3
As I've started searching for equipment... I had a few surprises.
You can find old engine driven balers that could be pulled by just about anything, but I think some of the newer equipment has increasing HP demands.
I just snagged a 7 disk mower, and was surprised by the 50 HP requirement. Even the 4 disk mowers list about 30 HP requirement.
I got a little two basket tedder that I'm planning to pull with my little Ford 1715, but the mower & baler will need something bigger.
1991 GMC Sonoma Pickup Truck (A48081)
1991 GMC Sonoma...
2007 TRANSCRAFT 48X102 FLATBED (A50854)
2007 TRANSCRAFT...
2011 RAM 5500 HD ARMORED TRUCK (A50505)
2011 RAM 5500 HD...
2017 Schulte FX107 84in Rotary Cutter Attachment (A50322)
2017 Schulte FX107...
2022 John Deere S780 Combine (A50657)
2022 John Deere...
2025 K3325 UNUSED Double Garage Steel Barn (A50860)
2025 K3325 UNUSED...
