what does a bleed value look like
   / what does a bleed value look like #1
millpond
NH TC 55 DA
I have New Holland tc 55 da and I'm looking for bleed valve on rear remotes, which may help with the QC on my grapple that's giving me trouble.
   / what does a bleed value look like #2
What kind of troubles are you experiencing?
Soundguy
Soundguy, I was having trouble with QD's for Millonzi grapple. It appears that
the female collars are really tough, but I also may not have released all the
pressure from the lines when I was trying to reconnect the grapple. I was just
curious on rear remotes HN tc55da want/where the bleed value looks like.
   / what does a bleed value look like #4
I believe there is no such animal.
If it's the connectors on the tractor side, you bleed the pressure off by shutting down the tractor and moving the hydraulic levers back and forth a few times.
If it's the connectors on the grapple side, a slight tap on the check valve tit should do it.
(Note; before tapping on the check valve, cover with shop rag.)
   / what does a bleed value look like #5
I have never seen one on a compact tractor. Some of the very large, very expensive tractors have them.
2008 CAT 287C (A50854)
2021 FORD F450 TOW TRUCK (A50505)
2021 FORD F450 TOW...
Willmar 4300 Wrangler Loader (A51039)
Willmar 4300...
Payment Terms (MUST READ) (A50775)
Payment Terms...
TAKEUCHI TB2150 EXCAVATOR (A51242)
TAKEUCHI TB2150...
2019 Generac MLTS-1 2.4kW Towable LED Light Tower (A49461)
2019 Generac...
