Buying Advice What older model Fords would you look for (40-80hp)?
   / What older model Fords would you look for (40-80hp)? #1
ah64_ip29
Bronze Member
New Hope, AL
Kubota L5030 HSTC
I'm kinda new to the tractor world, but have been learning a lot from this forum over the last few months. I've retired from the military after 24 years and my wife wanted horses, so now we have 5 on 17 acres.
Here's my question:
If you were looking for an older Ford tractor in the 40-80hp range, what models would you consider? Which ones are worth the time and effort to keep running and aren't too difficult to find parts for? Are some too difficult to add extra remotes to, etc?
Here's some background:
I originally thought I only needed about 40hp, with a loader, for moving round bales and mowing and fence post digging. I also anticipate moving dirt to level out a spot for a new barn and using a box blade, and other field prep/conditioning equipment, and maybe a baler at some point.
When it rains even a little i've found that I can't get my F350 4x4 dually out into the field without getting it stuck, to drop off a round bale. A local farmer has been driving his tractor about 4 miles to deliver the bales when it is wet (he has a McCormick 80hp 4WD) So, it seems 4WD might be important for me. Someone suggested that 4WD improves pulling so sometimes more hp is not required. Some have suggested that the extra hp is not that much more in cost so I should consider getting it if I can afford it, and it will give me the ability to lift the heavier loads safely if I should need it (without risking tipping over). I'm really new to all this tractor stuff, and as you can see, I've been getting advice all over the spectrum.
It seems there are a lot of fans of the older tractors. An older tractor doesn't bother me, as I used to be a certified auto mechanic, so I would think I'd be able to do a lot of maintenance if required, as long as parts were available, and ok, sometimes I like to work on stuff (turning something with potential into something worthwhile).
I'm trying to spend less than $20K, but am willing and able to spend whatever is required.
Thanks for taking your time to help out a newbie. Adrian
   / What older model Fords would you look for (40-80hp)? #2
For moving round bales are you going to be stacking them or just moving them? If just moving them a three point hitch (3PH) will carry bales and give a 2 WD tractor a lot more traction.
In the Ford line we had a 1966 5000 and a 1978 5600. Both in the mid 50's on HP but neither was 4WD. I don't know which models had the front wheel assist.
Thanks for your service in the military also:thumbsup:
Roy
   / What older model Fords would you look for (40-80hp)? #3
40-80 PTO HP: Ford 3910 (42), 4610 (52), 5610 (62), 5640 (66), 6610 (72), 6640 (76). Ford New Holland: 3930 (45), 4630 (55), 5030 (62). New Holland: TN65 (47), TN70 (57), TN75 (62), TL70 (56), TL80 (66), TL90 (76). Most should be within your $20k limit, all available with 4wd. Search here Used Tractors at TractorHouse.com: John Deere Tractors, used farm tractors and farm equipment, Case IH, New Holland, Agco, Ca... to get an idea of prices, may find something close to you that meets your needs.
Right now, I usually roll the round bales out of the back of the truck, so I guess I could do that, and then use the 3 point to move it to where it needs to go...
I've found a Ford 6600, 4wd, w/loader and bushog for $9000. Looks a little rough, haven't driven it yet. Is there anything special I should evaluate on these older Fords? Is this price in the ball park?
   / What older model Fords would you look for (40-80hp)? #6
is it a 6600 or a 6610? or xx10 II
soundguy
I'm fairly sure it says 6600 on it. From reading the forums, seems people like the -10s... why is that?
   / What older model Fords would you look for (40-80hp)? #8
xx10s just means it is the newest of that line.
ie.. 6600 , 6610, 6610 II, 6610s
soundguy
Tractordata.com has it built somewhere between 1975 - 1981
   / What older model Fords would you look for (40-80hp)? #10
Get something with four wheel drive. You will never regret spending the extra bucks. When you want to update it will bring more money and sell alot quicker.
2021 CATERPILLAR 303E CR EXCAVATOR (A51242)
2021 CATERPILLAR...
2018 PETERBILT 579 DAY CAB (A51222)
2018 PETERBILT 579...
CATERPILLAR 926M WHEEL LOADER (A51242)
CATERPILLAR 926M...
Case 580D (A47384)
Case 580D (A47384)
2016 Ford Explorer...
Quick Attach Pallet Forks (A47384)
Quick Attach...
