What size battery are you using in your Mits MT 372D?
   / What size battery are you using in your Mits MT 372D? #1
GeeVee
Bronze Member
MT 372 D, ASV RC30
I have a 410 CCA battery in mine, but dang, its a slow turning thing. I have recently had to have the starter worked on to replace the plastic gear cup. I think I will have the alternator worked over too pretty soon. And re-fresh the cables and shine up the connections.
Since there is ample room, I may be headed to a larger 750CCA, just because.
Anyone viewing this thread looking for info? Bill at Valley Power has Manuals for sale- just buy them if you need them. He does answer the phone and lurk here occasionally, so don't disregard his resource.....
My little girl usually runs pretty good with a 4' bushhog, and I don't usually have issues that require mechanical parts or repairs. Currently fighting water in my trans/hydro because I disregarded leaving it in the rain. New thread.
GV
   / What size battery are you using in your Mits MT 372D? #2
CCA does not correlate to battery size...
So Caustic, How many amos are you giving it to start it? It's about 6 inches x 9 inches by 12 inches. I got room for more with top posts or side posts. Lots of space.
GV
   / What size battery are you using in your Mits MT 372D? #4
GV
I use a BCI 22NF size myself, your sounds like BCI 21 size.
Edit: for size ref: BCI Battery Group Size Chart
Each size comes in different CCA depending on chemistry type.
   / What size battery are you using in your Mits MT 372D? #5
Personally I'd measure the available space and install the largest battery that would fit - but that's just me.
   / What size battery are you using in your Mits MT 372D? #7
I echo that, often very little $ difference for more cranking.
Maybe; RV, Marine, and glass core versions all have vastly higher CCA but cost a lot more.
If you are electrically inclined you can build a super cap and lithium cranking battery fairly cheap. That is what those 12V and tiny jumping packs are. $25-$100 will get you in the 1000-2000 CCA range for a few cranks.
2015 Ford Econoline Box Van, VIN # 1FDWE3FL4FDA28220 (A51572)
2015 Ford...
Ferris 52in Zero Turn Mower (A51694)
Ferris 52in Zero...
2018 Caterpillar CS54B Smooth Drum Vibratory Dirt Compactor (A51691)
2018 Caterpillar...
1261 (A50490)
1261 (A50490)
Tires (A50322)
Tires (A50322)
