Slade
What size chain would be adequate for pulling trees, etc. with the drawbar on a Kubota L5740? Would a Campbell 5/16 inch with a 4700 lb load limit be sufficient?
Slade said:What size chain would be adequate for pulling trees, etc. with the drawbar on a Kubota L5740? Would a Campbell 5/16 inch with a 4700 lb load limit be sufficient?
Half inch chain is hugely heavy. Thats bulldozer territory. The work load you quoted for the 5/16 tells me it is a grade 70 chain. Its minimum breaking strength is 19000 pounds. These are tough chains. Iv used them for years. You wont find a tractor under a hundred HP that will come close to breaking one w/o a running start. Iv done jerk pulls with a 6000 lb tractor - straightened 3/8" slip hooks or just stalled the tractor if the load didnt come. Chain didnt give a bit. Iv done steady pulls to the limit of traction with a 11000# tractor. No problem for the chain.Slade said:Thanks guys, I'll go with the 1/2 since I'll be pulling big fallen trees and good sized stumps out.
