ratter
Hey all you 1540 owners out there, what size finish mower are you able to get away with, and under what conditions? I'm assuming 6 and even 7 feet would be no problem under normal mowing conditions. But maybe even larger?
jacobweaver32 said:I run a HD woods 7' on the back of my 1533 with no problem. I cut down some weeds up to 4' high on my first use of it (hadn't brushed the 12 acres for 2 years) and the 7'er took um down no problem(sharp blades played a role I'm sure). However, I did run the deck about 5 inches off the ground... but still not bad. I'll have to post some pics it looks good. I can lift the deck with ease so that wont be a problem for you.
On the scalping issue... I do run into this now that I am on my second pass of the yard since ownership. I cut last night down to about 2 inches and in bumpy spots I do scalp a little. But to help that situation I drop the fel and run it alont the ground to knock off the anthills and such.
I guess a 7' will cover your wheels which is nice.... a 6' just seems way to small for that size tractor.
Good luck!
