Oil & Fuel What size is that oil filter?
   / What size is that oil filter? #1
BLue backhoe
Rock hill SC
LS I3040
I have an LS i3040 which is the same thing as a New Holland Boomer 35.
I need to find out what size oil filter i should buy. the New Holland part number is MT40219853
If anyone has any ideas or answers I'd be thankful
THanks
   / What size is that oil filter? #2
If it is not new and you are having trouble getting the factory replacement, and you are sure the NH part number will work....take that part number or the LS number if you can find it to almost any real parts store and they can cross it to their brand.
Parts manual for the C3040 here: (may not be the same)
http://partsforlstractors.com/files/C-S-Series_Parts_Manual.pdf
   / What size is that oil filter? #3
When I looked on the New Holland website for the oil filter on a Boomer 35 the number that they list is MT40056451. That number and the number that you gave (MT40219853) do not seem to cross to a WIX brand filter. Both New Holland and WIX have great websites. If you know the manufacturer and model of the engine then you should be able to get the WIX crossover number. The WIX website will also list the specifications for each filter i.e., height, O.D., thread size and on and on. It also will list other applications for the same filter.
2021 Ford F-250 4x4 Ext. Cab Pickup Truck (A49461)
2021 Ford F-250...
2005 JOHN DEERE 310G BACKHOE (A50458)
2005 JOHN DEERE...
PALLET OF (2) THERMOKING TRI PAC UNITS (A50854)
PALLET OF (2)...
2009 L3 GENERATOR SET (A51222)
2009 L3 GENERATOR...
Kenco PH9000 Self-Leveling Pipe Hook - 9,000 LB Capacity, 8FT Max Pipe Length (A51039)
Kenco PH9000...
PORTER CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTER CABLE 150...
