What size landscape rake for bobcat ct-122 (22HP)
   / What size landscape rake for bobcat ct-122 (22HP) #1
planters49
Bobcat 122
I'm looking at woods equipment landscape rakes for my bobcat ct-122 tractor. Should I get the 5 foot model or the 6 foot model? I also have a woods 5 foot rotary cutter.
   / What size landscape rake for bobcat ct-122 (22HP) #2
I would suggest a 5ft rake for that tractor. I had the same size (not Woods) rake for my previous 21hp (Kubota) machine and it worked well. The only problem was that the rake was built light and would not be quite aggressive enough in gravel. Adding 30lbs of weight solved that problem.
Thanks for the help. I got a quote on a woods lrc60 for 799.00 without the wheels and another 299 for the wheel kit. That seems really high. Does that sound correct for this rake? Is there another good one for around 500 bucks?
   / What size landscape rake for bobcat ct-122 (22HP) #4
I have a KK 72" and like it very much.
In my area you can buy a 60" for $449 a 72" or an 84" for $499 at Tractor Supply. I strongly advise a wheel kit too!. I don't have wheels on mine, it would make life easier. My rake usually does the raking on my 33 acre lawn each year, cleans up the mess on my log deck and puts in a couple of 3 acre lawns a year. don't under estimate KK equipment. . . .John
What does KK stand for?
Thanks, after doing some research it appears that the stuff at Tractor Supply store is the same as King Kutter. Is that correct?
1996 CHEVROLET CAPRICE SEDAN (A52576)
1996 CHEVROLET...
2015 Toyota Camry Sedan (A51694)
2015 Toyota Camry...
JOHN DEERE 7210R LOT NUMBER 264 (A53084)
JOHN DEERE 7210R...
2016 Case 821F Articulated Wheel Loader (A51691)
2016 Case 821F...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2006 KENWORTH T800 TANDEM SLEEPER TRUCK (A52141)
2006 KENWORTH T800...
