Rear Blade What size rear blade for my John Deere 1026?
   / What size rear blade for my John Deere 1026? #1
denverdave66
Missouri
2012 John Deere 1016, FEL, 60"MMM
The John Deere dealer told me I need to get a 5 foot rear blade, a lot of people say it will handle a 6 ft blade? What is everyone's thoughts? The JD dealer wants to sell me a Landpride 1560 for $525.
   / What size rear blade for my John Deere 1026? #2
Some will say..when blade set 45* should cover rear tires threads.
   / What size rear blade for my John Deere 1026? #3
get one the width of your rear tires.
   / What size rear blade for my John Deere 1026? #5
What the above gentlemen said... If you get a 5' blade it will cover your tires when angled. If you just want to use it for med/light duty snow and gravel you can pull a 6' behind your tractor without any trouble, but if you want to be able to sink it into dirt then 5' works better (I tried both). You won't hurt anything either way, you'll just spin your tires that much easier when carrying the bigger anchor. *grin*
It's worth getting the "L" units from JD/Frontier or a corresponding type unit from other brands. You can lift 6-8 hundred pounds back there, so the L isn't really light-weight... It's "lower height", which comes in handy. Basically since you have smaller tires, you'll have trouble holding something high off the ground back there and so a lower profile implement will match up nicely with your unit.
Something like the RB2060L would be perfect, but the 72" will be lovely to use as long as you are just skimming (snow, gravel) and not digging.
My 2c :)
HunterWare he recommened the Landpride 1560 is it really worth the $200 more than one you buy a Tractor Supply or other places? I prolly will stick with the 5 foot blade. Who makes the RB2060L?
I just did a search and saw the JD?Frontier makes that blade, my local JD dealer says he will not sell Frontier equipment he said Landpride is much better made the only way he sells it if the customer insists.
   / What size rear blade for my John Deere 1026? #8
I agree on the one foot over tire width but do not know your tire width or HP. I like Land Pride. Over the years it seems with equipment if I will up grade at time of purchase I am happier over the next 10-40 years. :)
I do know if one goes oversize too much it is hard to rotate the blade 180 degrees.
Just measured the width of my tires are 4' I have a JD 1026 R 26 HP diesel.
   / What size rear blade for my John Deere 1026? #10
i would get a TSC blade i have an 8 foot behind my 7040 kubota the only problem i broke the latch that hold the blade straight or on an angle i fix that problem cut i deep notch in it not a problem since my tractor weights 8300ibs i know a 1026 will not broke a 5 foot frm TSC the reason i broke it i caught a rock on the one side in a ditch and didnt stop that 1026 is a riding mower i call my 70 hp a garden tractor
UNUSED FUTURE XJ3T 3TON 30" HYD THUMB CLAMP (A51248)
UNUSED FUTURE XJ3T...
2016 E-Z Beever M12R Towable Brush Chipper (A51691)
2016 E-Z Beever...
UNUSED RYOBI 80V HP BRUSHLESS ELECTRIC PUSH MOWER (A51248)
UNUSED RYOBI 80V...
THOMPSON F4L 1011 PORTABLE DIESEL PUMP (A51406)
THOMPSON F4L 1011...
2025 SDLANCH SDLGC80 UNUSED Electric Golf Cart (A53117)
2025 SDLANCH...
2019 Ford F-550 4x4 Ext. Cab Chipper Truck (A51691)
2019 Ford F-550...
