What size wire for trailer brakes?
   / What size wire for trailer brakes? #1
Snowman9000
Bronze Member
Grundy County, IL
JD 755
My 16' utility trailer has brakes on one axle. I might put brakes onto the other axle too but that's another story. It has a small gauge wire running the brakes now. It's wired half-baked in general, so I figured when I improve it I'll put the proper gauge wire for the brakes.
So what size wire to feed two brakes, and what size to feed four? Thanks!
Edit: I found this article which says 18 ga. for a 5-wire system, which is the type I have. So maybe mine is good to go.
http://www.etrailer.com/faq-wiring.aspx
   / What size wire for trailer brakes? #2
18 seems pretty small. 14 gauge or 12 gauge is what I would use myself. Easier to work with and if you nick it or it gets corrosion you still have some diameter left to carry the current.
   / What size wire for trailer brakes? #3
4 brakes draw about 10 amps so 18g is too small IMO.
   / What size wire for trailer brakes? #5
We use #10 at my shop to rewire brakes. #18 is fine for the lights.
Chris
   / What size wire for trailer brakes? #6
Go to 6, or even better, 7 pole wiring (the defacto standard today). Add back up lights to the rear of the fenders, pointed out about 30 degrees. You will not be disappointed. Don't put too large a wattage lights or you'll blow the factory fuses.
Use a gauge thicker ground than the thickest signal wire, as all of the signals add up, makes sure the worst case will work well. And wire all the lights and brake ground to a common bolt near the tongue. Simplifies troubleshooting, improves current flow/continuity.
Brakes don't care which wire is hot, and which one is ground.
Personally, I have gotten to where I use sealed lights (already have a ground wire on them), a terminal strip at the tongue in a weather tight box using water tite fittings (you can find these for trailers, but you can use the standard electrical stuff at Lowes Depot). 3M makes an insulation penetrating splice connector (similar to telephone wiring connectors) filled with silicon grease. Works great, no stripping required, connects two or three wires. Sometimes Walmart stocks them, otherwise look around for a box, as more than a couple, you don't want to buy them at the auto parts store.
   / What size wire for trailer brakes? #7
Chris
So electric brakes are pulling 30A? Really? Sounds high to me... But that is the NEC spec on 10 ga. Sure, you lower the voltage drop issues, but trailer wiring distances aren't that great. Another poster noted that 4 brakes draw 10A...By all NEC codes you would be fine with 16ga for that. Me? I just rewired my recently acquired trailer (16', 2 axles, both have electric brakes) with 14ga for the brakes. Part of the issue was looking at the leads going to the brakes. They were small -probably 16. I didn't want to try and use large gage wire to feed them, so instead I split the wiring and did one axle with one run to the J-box, and the other axle with a second run. And I know that this was overkill. But it made connections easier.
I used 16 for the lights as I could find a nice roll of 4-bonded trailer wire in that range. Yeah 18 probably would have been fine for lights.
BTW I found these crimp on butt connectors that are also heat shrink. Those work well. Crimp on , then heat gun to shrink and seal. That makes a lot fosense for trailer work and I found them everywhere in electrical depts. I also used the 3M 806 (?) connector with the silicone goop in them for running splices. Got them from etrailer.com for not too much - you can buy individually from them. Otherwise you go to Shop 3M: Purchase 3M products online. and you can only buy a whole box of a couple hundred connectors for a couple hundred bucks... Great if you build trailers for a living I guess.
-Dave
   / What size wire for trailer brakes? #8
I use 10 GA because I buy it by the roll and keep it on hand to cover all the things I need. As for the connections I solder and heat shrink all. I have used the butt connectors with heat shrink and it works good also.
Chris
   / What size wire for trailer brakes? #9
NEC has no impact on trailer wiring, AC and DC don't behave exactly the same. It is a LOT easier to open an AC circuit than a DC one so you need to be more careful with DC ragarding ampacity of the wiring and connectors to avoid shorts.
If you are dealing with automotive wiring, use SAE standards and methods as outlined in various SAE papers and publications.
For automotive wiring at 10A resistive loads, 16 Ga is really the smallest wire you should use and 14Ga would be a better choice but not needed.
Every trailer ground should be at least 10GA and common with all other grounds connected at a central point. However, this is rarely done and is one primary reason why so many trailers have lighting problems.
   / What size wire for trailer brakes? #10
14Ga I'd say. If it were I, I would end up using 12Ga, that's just me.
You should see the wiring harness for semi trucks. I think the ground wire is 8Ga wire and the anti lock brake hot wire is 10Ga- or was it the other way around(?). I think the smallest size is 12Ga. Been a while since I worked on my semi trailers.....
But the most common issue is grounding. Or lack of grounding. Most of all the lights self ground. But after a few years, they end up rusting and loosing ground. Age and wear show up eventually. Having a few ground points for the ground wire helps a lot. I have an old semi trailer that we use to haul grapes- not a tanker- but flat bed w/ stainless/fiberglass tip tanks. Grape juice and washing it takes it toll! I grounded the ground wire to the back main frame AND the front. Then ran a wire from the frame to the bed frame...just in case.
New/Unused Electric Golf Cart (A57453)
New/Unused...
2017 Ford Explorer SUV (A56859)
2017 Ford Explorer...
Kawasaki KLX140L Dirtbike (A59225)
Kawasaki KLX140L...
2019 PETERBUILT 579  DAYCAB (A58214)
2019 PETERBUILT...
2018 SkyJack SJ1056TH 10,000LB 4x4 Rough Terrain Telehandler (A55973)
2018 SkyJack...
CAT 289D3 (A58214)
CAT 289D3 (A58214)
