What thread type/TPI does the US use on garden taps?
   / What thread type/TPI does the US use on garden taps? #1
100 td
Platinum Member
ɹǝpunuʍop
Kubota B21TLB (B21, TL421, BT751) Toyota SDK4, T116 Bobcat
Looking to buy some Claber 8488 water timers, Dual Select - 8488 need to know what tap outlet thread you guys use, type and TPI, to see if I can utilize in Australia. One other problem I also see is that your quick connects may be different, so the outlet thread of the timer fittings may need to be checked as well.
   / What thread type/TPI does the US use on garden taps? #2
Thanks Bruce, so it's not going to mate with our 14 TPI!
   / What thread type/TPI does the US use on garden taps? #4
Nearly the same as our standard 3/4" water pipe except not tapered. They can be interconnected.
14 TPI tap screwed into an 11.5 TPI plastic threaded timer fitting at 150 psi isn't going to work unfortunately, and I don't have a lathe to make something up. I'll have to find something else. I liked this one due to its dual programmable outlets, 174 psi max pressure, slow close solenoid.
Maybe I buy some brass adapter fittings and silver solder to something of mine, anyone know what the smaller outlet thread type/TPI is on the timer?
   / What thread type/TPI does the US use on garden taps? #7
Claber is an Italian company. Maybe the tap thread is 14 TPI.
Contact us
Bruce
I don't think I can convert my inkjet to a 3D printer!
I have emailed Claber for thread details.
2011 PETERBILT 384 TANDEM AXLE TANKER TRUCK AND TANKER TRAILERS (A54607)
2011 PETERBILT 384...
2019 Dodge Durango (A53421)
2019 Dodge Durango...
TORO MBTX 2500 STAND-ON CONCRETE BUGGY (A51406)
TORO MBTX 2500...
2023 CATERPILLAR 259D3 SKID STEER (A52705)
2023 CATERPILLAR...
JOHN DEERE 437E KNUCKLE BOOM LOADER (A51246)
JOHN DEERE 437E...
Advance SC750 28in Floor Scrubber (A53421)
Advance SC750 28in...
