What to look for in a brush hog?
   / What to look for in a brush hog? #1
tomfifield
Eagle creek Or
Kubota 3400
I am going to be cleaning up a lot of black berries small trees and brush. I want a brush hog that will do the job. I will be using it behind a L3400 hst. 34 hp. What one's are strong and what is your experence with them/
   / What to look for in a brush hog? #2
tomfifield, How big around are the tree's?? Do you have any rocks that you might hit ? Cutting big stuff and hitting rocks beats the sides of a mower pretty hard. Do you want a slip clutch? I look at it....tree's 2 inch round and smaller is one price/brand and 2 inch up is another price/brand.
Just something to think about?
Ronald
Ranch Hand Supply
   / What to look for in a brush hog? #3
<font color="blue"> I am going to be cleaning up a lot of black berries small trees and brush. I want a brush hog that will do the job. </font>
If we had a customer ask us that question, we would suggest a laminated tailwheel, stumpjumper,flexhitch at the toplink, 1/2 inch thick blades, greasable tailwheel wear bushings or timken bearings, 40 hp gearbox, slip clutch with series 4 driveline (minimum) 7 guage deck would be good if you have a lot of rock.--Ken Sweet
   / What to look for in a brush hog? #4
Hi tomfifield
I would suggest getting the most you can afford... I bought a JD MX-5 to do fairly heavy brush clearing, and have been pleased with it...
If I had it to do over, I think I would try to swing a Woods BB600 (although my PTO is rated for MX-5 maximum), the price difference was minimal... but everything is green!
Those 2 units are built like tanks, have standard stumpjumpers & slip clutches, gearboxes you could never overpower (with the 3400), have stand-up companies backing them, and can shred anything you can get your tractor over, although they are pricey!
Be sure you get one with a slip clutch instead of shear pins; check the thickness of the deck & sides--at least 1/8 inch on top & 1/4 on sides, easily replaceable skids are nice, get a 2" rating for cutting if you can afford (then you won't have to ask "should I have...") and you can choose bigger projects down the road if you wish, or at the very least, have a field mower that is sure to stand up to any accidentals you might run into.
My 2 cents anyway... best ones I found when in your boat...
Good luck (& have fun!) /forums/images/graemlins/cool.gif
HARDEE RD72M LOT NUMBER 154 (A53084)
HARDEE RD72M LOT...
2005 Nissan Titan (A50121)
2005 Nissan Titan...
Toro Zero Turn (A50324)
Toro Zero Turn...
2015 KUBOTA 1140CPX RTV (A51406)
2015 KUBOTA...
2016 Chevrolet Tahoe SUV (A51694)
2016 Chevrolet...
Generac Generator (A51691)
Generac Generator...
