drm
I got to try out a ESAB MigMaster 253 today. WOW, MIG welding is definitely cool (or should I say hot!). I am completely hooked. I have been reading the web, books and purchased two instructional videos from Wall Mountain but never expected it to be as smooth as it was to start out. After some instruction and demonstration of the machine and proper technique I was laying down some OK looking welds. Unfortunately the penetration was also just OK. I definitely need lots of practice and instruction. Only burned back the electrode once. Got a few good passes on ¼” stock and got to play with the voltage taps and wire speed. I am beginning to understand the adjustments I had only read about till now.
I will be primarily welding 1/8” to ¼” mild steel material with 3/8” at times and most likely ½” max. I want the ability to weld the ½” when required but multi pass would be acceptable. The heavier material would be limited. I also want the ability to do body repair and fabrication down the road.
The ESAB has similar specs to the Lincoln Power Mig 215 that I was considering:
ESAB MigMaster 253
40-250 amps
12 Tapped Voltage
20% Duty - 250 amps
30% Duty - 200 amps
60% Duty - 140 amps
Power Mig 215:
30 - 250 amps
7 Tapped Voltage
20% Duty - ?
30% Duty - 215 amps
40% Duty - 190 amps
60% Duty - 170 amps
After my play day I have a few questions.
I noticed the difference in the weld when changing just one position of the 12 tap ESAB. Is the 7 tapped voltage of the Power Mig 215 a concern since it has fewer positions?
The ESAB seemed to be very smooth. Is this characteristic of all MIG welders in this power range?
Does anyone have experience with the ESAB 253? How does the ESAB stack up?
Again thanks for all of the great advice.
…Derek
ESAB MigMaster 253
40-250 amps
12 Tapped Voltage
20% Duty - 250 amps
30% Duty - 200 amps
60% Duty - 140 amps
Power Mig 215:
30 - 250 amps
7 Tapped Voltage
20% Duty - ?
30% Duty - 215 amps
40% Duty - 190 amps
60% Duty - 170 amps
…Derek
