What would you do?
   / What would you do? #1
neilly2
Bucks County PA
Kubota L285 with V1500A engine
My tractor was not manufactured with ROPS. At the recommendation of Kubota, the dealer supplied an aftermarket roll bar when I bought it, to cover his butt.
Its going on 4 years in the shed and I haven't installed it yet. Bearing in mind the the "S" in ROPS stands for system, meaning a roll bar AND a seat belt, I felt that installing it would not really serve a purpose since I don't have a belt.
Now, I'm itching to install it as use for a canopy and lights.
What would you do?
I'm not preoccupied with safety in general (I believe that smart, thought out operating is the best safety)
   / What would you do? #2
I would not install a ROPS without a seatbelt. I occasionaly don't wear my seatbelt but I usually do. I always do when using a FEL or anthing engaging the ground. I always do when going up and down hills. I usually do when mowing the flat spots. But if you install the ROPS and that very rare occurance happens and you roll, and you don't have a seatbelt then you have a really big problem! If you want to install lights, buy a seatbelt too.
   / What would you do? #3
Are you sure it doesn't have a seat belt in the package?
I bought a ROPS and seatbelt for my L345 2 years ago. It is a Kubota item, and I would be very surprised if a Kubota dealer provided anything else. In fact, the L345 and L285 ROPS are the same - see this page..
In any case, I would install the ROPS with a seat belt. If you install it without a seatbelt, it'll be the ROPS that crushes your skull in a rollover. /forums/images/graemlins/shocked.gif
No, there definitely wasn't a package. It defintely was a kubota dealer and a kubota bar. He just dropped off the bar and mounting hardware when it came in. There wasn't much discussion during the tractor transaction, just a few grunts. I bought it back East.
I am having trouble picturing the bar crushing your head. If the tractor rolls to the side or the back, I imagine your head would hit the ground after the bar did. Isn't the bar also to prevent multiple rolls?
Has anyone rolled one that can describe what happens?
   / What would you do? #5
</font><font color="blue" class="small">( Isn't the bar also to prevent multiple rolls?)</font>
No. The purpose of the ROPS is to create a space for the operator to be in so he/she won't be crushed by the tractor. The purpose of the seat belt is to keep the operator in that space.
   / What would you do? #6
Most tractor seats have a place to bolt on seat belts. Or if they dont you can take the a bolt out of the seat mount bracket and then put your bolt through the seat bracket and ut it back on the tractor. I recall that set up on a factory installed belt on a 5000 Ford. Ive used alot of tractors with a rops and no belt I now its not 100 percent safe but its safer than no rops. Ithink TSC sells a belt kit, Or ou could order one from a tractor dealer, or one from a truck shop most of the dummy/passengers seat belts are after market replacements.
   / What would you do? #7
Install it. Many, many older tractors are installed with ROPS that do not have a seatbelt. The ROPS will save your life. Yes the safety belt would be ideal as well but that ROPS is the most important. I know many people, myself included, that have rolled or tipped a tractor over and have been just fine without a safety belt. Without the ROPS though it could have been a different story.
   / What would you do? #8
neilly2,
Well, the "crush your skull" comment was hyperbole on my part, but I've always been told "If you have a ROPS, always wear your seatbelt so the ROPS doesn't crush you. If you don't have a ROPS, don't wear a seatbelt, so you can try to jump clear in case of a rollover".
Your ROPS bar should have a serial number on it and a call to a local or mailorder Kubota dealer should result in a seatbelt in your possession. But, I would first go back and open your bolts and nuts package and doublecheck for a seatbelt.
   / What would you do? #9
I agree with cowboydoc (I usually do), and suggest you install the ROPS. Also, find a seat belt and install it as well. But, I think the worst scenario is to roll the tractor without either ROPS or seatbelt, the next best is with the ROPS and not wearing a seatbelt (that's me), and the very best is the ROPS and wearing the seatbelt.
But, the scenario of no ROPS and wearing a seatbelt, is (IMO) not good if the tractor rolls over.
Having a ROPS in the barn when you roll the tractor isn't going to look too smart, IMO. The coroner might make a comment, and your wife's relatives might just verify what they suspected all along. /forums/images/graemlins/grin.gif Hopefully this is enough encouragement to get you off 'dead' center. /forums/images/graemlins/wink.gif
   / What would you do? #10
neilly2,
I can't describe what happens when you roll your tractor (thank goodness), but here is a discussion from 2002 that discusses some issues with the ROPS installation. Good luck.
2025 LandHero Mini Excavator (A45336)
2025 LandHero Mini...
Row Gator RG1100C (A46878)
Row Gator RG1100C...
Compactor (A45336)
Compactor (A45336)
2014 Scion xB Hatchback (A44572)
2014 Scion xB...
10 Gallon Antifreeze Tank (A47369)
10 Gallon...
2018 Ford Taurus AWD Sedan (A44572)
2018 Ford Taurus...
