Ballast Wheel ballast for kubota L2800
   / Wheel ballast for kubota L2800 #1
boatman22
I have a new L2800 Kubota. I am looking for the rear wheel weight kit for industrial wheels and tires. Any suggestions?
   / Wheel ballast for kubota L2800 #2
Get a set of weights that will fit in the dish and don't obstuct the whell center bolts and drill the holes that you need.
   / Wheel ballast for kubota L2800 #3
boatman22, hey, Welcome to TBN... are the tires loaded with fluid or is there a reason you want the wheel weights vs. the fluid? I have not seen wheel weights for R4 tires.
Yes the rears are filled with water. I have the forks on the front to unload and load at my business. It seems that anything over 5-6 hundred pounds puts excessive weight on the f tires and makes it hard to steer. We have a 3P hitch on the back for moving boats around the lot, so a ballast bucket would not work.
   / Wheel ballast for kubota L2800 #5
Hmm, I am sure that if you got a ballast box, it can be made to modify to accept a receiver hitch or perhaps build one with a hitch built in? adding wheel wieghts to rear would help too but not sure which ones fit, hav eyou given your dealer a call about it yet ?
   / Wheel ballast for kubota L2800 #6
Look at this thread... weight in a ballast box with a receiver hitch, since it's behind the wheels... will help more with taking weight off the front tires (a bit) then just more weight at the rear wheel.
More Ballast Box Modifications - TractorByNet.com
Ok thanks for all the reply's. I think I will just modify the the hitch to hang some weights back there. I was looking for a simple way....but things aren't always simple.....Great site, I have learned more that I wanted too.
DAEWOO MG 250-3 (A52472)
DAEWOO MG 250-3...
AUCTION STARTS HERE @ 9AM (A51406)
AUCTION STARTS...
2022 K-Z Sportsmen 260BHSE 28ft T/A Travel Trailer (A51694)
2022 K-Z Sportsmen...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
Wolverine BC-13-72W, 72" Skid Steer Brush Cutter (A52384)
Wolverine...
2024 JOHN DEERE FC 10 R LOT NUMBER 84 (A53084)
2024 JOHN DEERE FC...
