When setting main relief valve do you take engine to full rpms?
   / When setting main relief valve do you take engine to full rpms? #1
Hersheyfarm
Veteran Member
NE ky
My max psi is supposed to be 2950, at idle it's 2800, at full rpm it's 3050. Should I back it off?
   / When setting main relief valve do you take engine to full rpms? #2
It wouldn't hurt, but it's close enough I wouldn't bother. If your tractor is still under warrantee I would back it off.
   / When setting main relief valve do you take engine to full rpms? #3
Sounds perfect. Youll find it to be a little lower when hot.
   / When setting main relief valve do you take engine to full rpms? #4
Depending on what the factory specs are. On my Branson the settings are at PTO speed not full RPM. I personally would leave it alone.
   / When setting main relief valve do you take engine to full rpms? #5
It wouldn't do any good to back it off. If the relief opens at 2800psi and you run up to full rpm the flow is more then the reief can handle, so it well build more psi.
   / When setting main relief valve do you take engine to full rpms? #6
It's quite unlikely that a factory matched relief valve will be overrun with flow from an OEM pump. They are pretty much spec'ed to work together.
   / When setting main relief valve do you take engine to full rpms? #7
Then why did the even use a relief valve? On a factory built machine it won't happen.
   / When setting main relief valve do you take engine to full rpms? #8
4570Man & RickB that should be true and I would say in most cases it is , but why is he getting more psi when he ups the rpm and getting more flow? Something is holding the oil back.
   / When setting main relief valve do you take engine to full rpms? #9
Because he adjusted the relief valve higher.
   / When setting main relief valve do you take engine to full rpms? #10
Nope I wouldn't change it either. That spec sounds very familiar :D. What model is it?
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
RIGID TOOLBOX (A50854)
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
2016 CATERPILLAR 259D SKID STEER (A51242)
2016 CATERPILLAR...
2019 Allmand Light tower (A49461)
2019 Allmand Light...
12 FLATBED W/ 300GAL WATER TANK (A50854)
12 FLATBED W/...
