JimR
Elite Member
What started out as a very simple easy repair turned into a day of work. I didn't feel like working much on Sunday. I figured it would be a good day to adjust the valves on my 27 horse Cub Cadet. Mind you the dealer I bought this used tractor from told me that he had just done them when I bought it, HA. Never believe them unless you see them do it. I have put 250 hours on this machine in the last two years. Upon opening the hood I found that my oil cooler has sprung a leak. I cleaned it all up and found a the leak. It is not repairable of course and I will have to replace this. The valves were way the heck off. I want to say that they haven't been adjusted in many many moons. A few of them took a whole turn to tighten them up. No wonder my motor was clacking. Of course the valve cover gasket broke and I needed to make another as the dealers are closed on Sunday. The tractor runs like a quiet machine now. I go to drive away and lift up my MMM only to find the 3ph is not working now. Now I'm scratching my head wondering what the heck did I do to deserve this. There is a 1/4" rod that goes from the right side lift arm to a lever that controls the lift mechanism. This rod had broken way up under the tractor. The swivel on the other end had frozen up. Now I need to figure out a way to get the drift pin out of this lever that is 14 inches inside the underneath of my tractor. Viola, a thought comes to mind to use a pin punch, a steel tube and a foot long brass rod all taped together. This works out great. I get it all apart, weld up the rod and re-install it al. It works nice and smooth once again. While I'm at it, I figure I might as well make sure the adjustable side link gets taken apart and greased up. I should have thrown it away and just installed a new one. Again, it is Sunday, nobody's open. Two hours later, my largest pipe wrench, a pipe, tons of penetrating oil and I'm back in business. What did I do to deserve this torture on a hot summer day? At least it is all fixed now except for the slighlty seeping oil cooler. I don't even want to think about the price for one of them.
