Where can I buy 50mm Rod stock?
   / Where can I buy 50mm Rod stock? #1
racerboy832
Connecticut
Deutz Allis 5220 w FEL and Backhoe
I need to replace badly pitted track adjuster rod on my Mini EX. They are 50mm X 137mm long. It looks like hydraulic cylinder stock. Where can I buy some of that?
   / Where can I buy 50mm Rod stock? #2
Just do a search on hydraulic cylinder rod stock and you'll get many places. Some hydraulic parts/repair shops stock it too. Is it plated or un-plated? Threaded?
50mm is a common size the 137mm is a pretty short piece. You may have to buy a minimum length unless a repair shop will cut it.
The local place is usually way expensive. I will google around some more to see whats out there.. Any idea how hard that stuff is to cut?
   / Where can I buy 50mm Rod stock? #4
McMaster-Carr
McMaster Carr. I'm not sure what kind of shaft you need but this will get you in the ball park.
   / Where can I buy 50mm Rod stock? #5
How hard it is to cut will depend on what type and state (hardened/not hardened) of the rod. Common W-1 drill rod in mill state can be machined but is pretty hard to begin with. It varies at ~RC-30 to ~RC-45. I use a lot of it for making one-off rolling dies for my bead roller (sheet metal work). How you plan to cut it is another question. Machine cutting is pretty easy but if you're talking about a hacksaw, that's a different story.
It may be cheaper to just have a machine shop make you a new one or order one from a dealer. You don't give many specs or details. Your question was; where can you buy rod. I can lay down five pieces of rod that look the same but have entirely different metal qualities and hardness.
It could be basically any steel. The original one looked like cylinder rod material. I figured 50mm cylinder would be common. It's just a slack adjuster for a track. It doesn't move unless you put grease in it. The original one is extremely pitted.
   / Where can I buy 50mm Rod stock? #8
Did you find a piece yet?
I have a cutoff of 50mm x 7.6" I can send.....chrome plated
   / Where can I buy 50mm Rod stock? #9
Ooops, spoke too soon.....that piece has a partial saw cut it it....I'll check further
   / Where can I buy 50mm Rod stock? #10
Found another good used 18" piece, you want it cut to size?
1272 (A50490)
1272 (A50490)
Boat motor turns (A51694)
Boat motor turns...
2005 NEW HOLLAND DC95WT CRAWLER DOZER (A51406)
2005 NEW HOLLAND...
2020 CATERPILLAR 303.5E2 CR EXCAVATOR (A51246)
2020 CATERPILLAR...
20 ft. Shipping Container (A53117)
20 ft. Shipping...
2023 LMC H40024 LOT IDENTIFIER 190 (A53084)
2023 LMC H40024...
