Where can I suggest improvements to manufacturer
   / Where can I suggest improvements to manufacturer #1
dakota-2000
I have a 5600C Turbo with 200 hours on it. I blew a valve stem out by hitting a branch on the ground. Scared me half to death. There is only one other TC in my area but every skid steer I checked since had at least one and sometimes more metal screw on valve stems as a replacement.
Also the bracket that holds the oil reserve tank to the frame under the passenger is so light weight that it broke within a few hours use. I had the bracket welded and a plate welded under the oil tank to help support it. I suppose TC isn't going to worry about that as the new "D" will have the engine there. Should get delivery on a "D" in a couple weeks.
   / Where can I suggest improvements to manufacturer #2
As far as the valve stem goes - __it happens. I wouldn't call that a manufacturing problem. Skid steers may have metal ones because of how then move. Then skid and more prone to hitting something on the side of tire/rim. Some skid steers will even have a metal ring welded around the stem to help protect it.
The weak oil reservior bracket may be a legitimate complaint. Probably just a poor weld.
The skid steers I saw had some of the rubber stems replaced with metal stems. Evidently they have blown out the rubber stems. I would think if Bobcat knew there was a problem they would correct it. I just wanted to know if there was a place to voice suggestions other than the dealer.
The reservoir bracket broke just beyond the mounting bolt, no weld near.
   / Where can I suggest improvements to manufacturer #5
The D has the really short metal valve stems.
TC is getting smarter. Thanks
2021 New Holland P2350 Air Cart  New, Tow-Between, Intellirate Control, Dual Tires (A51039)
2021 New Holland...
Yale 50LX Cushion Tire Forklift (A49461)
Yale 50LX Cushion...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
2015 FORD F750 26FT BOX TRUCK (A51219)
2015 FORD F750...
BREWSTER DRAWWORKS WITH TWIN CATERPILLAR ENGINES (A50854)
BREWSTER DRAWWORKS...
1998 Lexus ES300 Sedan (A48082)
1998 Lexus ES300...
