Where to get hydraulic cylinder parts?
   / Where to get hydraulic cylinder parts? #1
mopardude318
Platinum Member
Hollister Ca
Kubota M7060 HD12 Oliver 550
Hi. This is a power steering cylinder off my Oliver tractor. It is a welded cylinder not typically rebuildable. They are not available new so I cut it apart in an effort to rebuild it. I can get the front seal kit for it which is still available. What I need is a new ram/piston as this one is bent and the hard chrome surface is worn. So where can I get a new hard chromed shaft? It's 16" long and 9/16" diameter (.5625") with 1/2-20 threads on the tie rod end. I'm sure I can machine the other end to accept the piston side if needed. If nothing else, couldn't I get a length of hard chromed rod and machine both ends?
Hopefully I'll be able to TIG weld it all back together. :)
Never mind got it covered went to a local hydraulic shop and they're going to make the rods up everything I need just the way it is.
Thanks!
   / Where to get hydraulic cylinder parts? #3
Good deal!
2016 Toro Groundsmaster 3505D 72in Rotary Mower (A51691)
2016 Toro...
1992 SYLVAN 20' PONTOON BOAT (A51247)
1992 SYLVAN 20'...
UNUSEDX-STAR 72" QUICK ATTACH GRAVEL LEVELER (A51247)
UNUSEDX-STAR 72"...
UNUSED SWICT 72" QUICK ATTACH BUCKET (A51248)
UNUSED SWICT 72"...
2001 Subaru Outback AWD SUV (A51694)
2001 Subaru...
2016 Nissan Sentra Sedan (A51694)
2016 Nissan Sentra...
