which is better
   / which is better #1
laen64
Ashford Alabama
Bobcat CT335 SST;FERRIS IS 1500Z 25hp 52"
I'm in need of removing a large amount of WEEEEEDS. about 2 acres, which is better to use prior to seeding? Sod cutter or Box Blade?
Do give all opinions and instructions.
   / which is better #3
I agree with Kenny. I gave it about two weeks between the first and second applications, just so the new weeds could get their hopes up.
   / which is better #4
I would try a shot of glyphosate (Roundup is one brand) wait 2 weeks, and give another shot of glyphosate.
Neither of the implements you mention will do a whole lot on 2 acres worth of weeds.
--->Paul
   / which is better #5
If you are in an area where you can kill it and then burn. All the weed seed that is not burnt will pop from the heat of the fire. This will save some money on chemicals. Not all places are safe to burn... KennyV.
   / which is better #6
Once you get rid of the weeds how will you prepare the soil and what are you planting for seed?
   / which is better
Hydro I plan on seeding, that has proven to be tooo much to sod.
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
2007 Nissan Armada Multipurpose Vehicle (MPV) (A51694)
2007 Nissan Armada...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
VERMEER RTX130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX130...
2005 PETERBILT 357 TRI AXLE DUMP TRUCK (A52576)
2005 PETERBILT 357...
