Which Kubota is the equivalent to JD 5103?
   / Which Kubota is the equivalent to JD 5103? #1
mstewart44
I'm looking at the JD 5193 2WD 50 HP tractor. But before I buy, I was wondering which Kubota was the equivalent to this Deere?
   / Which Kubota is the equivalent to JD 5103? #2
Would think the MX5000 would comes closest.
   / Which Kubota is the equivalent to JD 5103? #3
In the Kubota comparison, the MX5000 is about 1000 pounds lighter than the JD 5203. That's a lot of weight and I imagine that the 5203 is a more robust tractor. But sometimes less weight can be an advantage.
I'd also look at the M5040 although it might cost more than a 5103. The 5040 is much closer in weight to the 5203.
I have a typo which I think most of you recognize, I'm consiering the JD 5103, not the 5193.
Marc
   / Which Kubota is the equivalent to JD 5103? #5
I was going to say the M4800SU. Apparently they're available in both 2WD and MFWD, although Kubota.com only specs out a 2WD. It's a little more robust than the MX5000 and has the planetary final drive like (I believe) the 5103 has. Still, the 5103 appears to be a much heavier tractor and it's 179ci engine will certainly produce more torque than Kubota's 148ci.
The M4800 transmission is 8x4 while the JD has a 9x3 in its most basic config. Both have 14.9x28 rear tires (R1) and the 3PH lift capabilities are very similar at around 3K lbs. The Mx5000 has 26" rears and significantly less 3PH muscle.
However, the M4800 probably runs about $3K to $4K more than the 5103. 'Made in Japan' can't compete with other Far East mfg on price. Looked hard at a MFWD M4800 this summer; never got the quote 'cuz it was too early to jump. Would like to replace my two oldest tractors with one.
Bob
John Deere 6125M (A50120)
John Deere 6125M...
2019 ExMark S-Series 72in Zero Turn Mower (A51692)
2019 ExMark...
2009 KUBOTA M7040 TRACTOR (A51406)
2009 KUBOTA M7040...
2014 Bobcat 5600 Toolcat (RUNS) (A50774)
2014 Bobcat 5600...
2015 John Deere 410E (A50322)
2015 John Deere...
