Buying Advice Which tractor for a very small farm?
   / Which tractor for a very small farm? #1
owkaye
Biloxi, MS
none
My wife and I bought 1.1 acres. The upper half was previously cleared so it only has a few trees on it. We want to plant a lawn and grow a garden in this part of the property. The lower half of the property has never been cleared. It is relatively wet with lots of tall trees that we have begun to remove one at a time.
Our goal is to get a tractor that will help us to do some of the work involved in clearing the lower half of the property, dig ditches for the installation of underground drain tiles (to help lower the water table and dry out the lower half of the property), dig a small pond for our ducks (maybe the size and depth of a typical above ground swimming pool), pull a box blade to help level and reshape the ground in some areas, till the soil in the garden 2-3 times a year, cultivate between rows in the garden, pull a landscape rake to help prepare some areas for planting a lawn, drill post holes along the property lines for the installation of new fencing, etc.
We already have a good riding lawnmower so we won't be using a tractor to cut the lawn.
The reason I'm explaining all this is so you'll have a good idea of the tasks we hope to accomplish on this property with a small tractor. Our problem is that we are new to tractors so we need some suggestions. This is all homeowner work and we are not in a hurry to get it all done immediately. Instead we prefer to take our time and do as much as we can ourselves ... with our own small tractor and implements.
Please post your suggestions for a tractor you feel can help us. There is no way we can afford to buy a new tractor, so we are definitely in the market for a good used tractor and the appropriate accessories.
   / Which tractor for a very small farm? #2
If youi are going to dig ditches and a pond and I am sure a few stumps , you need a backhoe , mini excavator , or the like . You need to talk to a contractor , agree on the rough out , be assured he will show up and complete the job. Then you can buy a little tractor to do maintenance . I can see you being stuck or worse if you don't think about this .,.
   / Which tractor for a very small farm? #3
:welcome:
   / Which tractor for a very small farm? #4
You need to rent instead of own till the big work is done then by a subcompact to maintain your land
   / Which tractor for a very small farm? #5
The more you look/shop the better the odds of finding what you want (including attachments)...leave your number with as many new and used dealers as you can...
in the mean time if the surrounding properties have not been cleared...take note of the available sun for your garden plot throughout the season...
   / Which tractor for a very small farm? #6
:welcome: Owkaye...
Having read you post, i'm guessing you have quite a tight budget for this? If that is the case I think you're going to have a challenge finding a small tractor and all the attachments you'll need to complete the project without spending more than you want (or probably need) to... As has already been suggested you could look at renting some of the machinery - for example hire in a mini excavator to dig the pond, holes for trees and even some of the rough landscaping - most mini excavators have a blade, and being tracked would be ideal for clearing your lower ground.
You might then want to look at what implements you can get to fit your lawn tractor - there are an increasing number of attachments being designed for quad bike / atv's including spring tine cultivators etc - depending upon the size of your lawn tractor you could maybe fit a tow ball and make use of these light weight tools to do much of the work?
If you're really wanting a tractor, then I'd look at selling your existing mower and replacing it with a more conventional CUT with mowing deck (or even finishing mower that attaches to the 3pt hitch) - Some of the older "small" Kubotas would fit the bill nicely, although beware that I have heard Kubota pto's work anticlockwise (meaning you would need proper Kubota attachments if they are pto powered) - I don't have much experience with Kubota myself, but I am sure someone else here on TBN will be able to tell you if that is the case...
You might also want to look at some of the older small articulated tractors (Pasquali etc)... Or you could consider looking at the Chinese tractors - a Jinma 204 would suit you perfectly, and can be fitted with Front end loader & back hoe if you need... (I'm must admit to being a bit biased towards Jinma, as I own one myself and also sell them here in Spain!)
What ever you choose - enjoy your land, and your tractor seat time....! :thumbsup:
   / Which tractor for a very small farm? #7
For 1 acre of ground you don't need a large tractor. Hire the drainage work out, then you can get yourself a small Subcompact tractor like the Massey GC series, or the Kubota BX series, or the John Deere 1026r. All the above tractors have a 3pt. hitch and rear PTO for attachments. Some come with small backhoes, and mower decks can be used on all the above.
   / Which tractor for a very small farm? #8
I have 2.5 acres and the Kioti 20 HST is perfect for my needs.
   / Which tractor for a very small farm? #9
2 wheel walk behind.
Hire out your few big tasks which only occur once (tree removal, ditches) and get a 2 wheeler off Criags List with the appropriate attachments. I've frequently seen them sold there because someone with more acres thought they could get by with a 2 wheeler.
Do not forget to get a picture of a snowblower attachment.
My grandfather managed about 2 acres of garden and a small woodlot with a gravely.
IF you feel you HAVE to have a 4 tire machine and money's tight, look for an older, small Ford or IH 2WD. Only if you have a good chance of getting more acreage or you have health issues could I see going up to a 15 OR 20 hp SCUT.
   / Which tractor for a very small farm? #10
I concur here except hiring out the work like digging ditches. You CAN do it with the FEL. I cleaned my existing ditch with FEL even though I have a backhoe. I just felt the FEL is better choice at the time. If I had to dig quite a bit of dirt for a neew ditch- I'd switch to my BH. But stumps or clearing trees - you cant beat a backhoe. However I have 2 acres and I think maybe a BX with BH might be a tad overkill for 1.1 acres. You can always rent out a mini excavator for one day if you have enough work for it. Much cheaper and easier. If you want to install drain tiles and have it to be 4 ft wide - the FEL on subcompact like don87 said is a great choice. I know you said you already have a riding mower, but I bet that once you get your new tractor - you will see its a simple add on and one less engine to maintain. I loved my BX for mowing since it was sooo much cheaper on fuel. Before I would go through 1-2 tanks per mowing and it was 2.5 gallons. With my BX, I can mow several times and still have enough leftover for other tasks with 5 gallons of diesel at a time.
Non running toro mower (A48082)
Non running toro...
2022 FREIGHTLINER M2 24FT BOX TRUCK (A51222)
2022 FREIGHTLINER...
2011 Ford Ranger Pickup Truck (A50323)
2011 Ford Ranger...
2017 Dodge Charger Sedan (A50324)
2017 Dodge Charger...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
Vermeer Vac Trailer (A49461)
Vermeer Vac...
