Who makes or has plans for FEL - JD 445
   / Who makes or has plans for FEL - JD 445 #1
Sel
WI
Mid 90's Craftsman
I lost out on an FEL locally because it went to auction (never knew), and I'd like to know who makes FEL's for a JD 445 garden tractors? What model number of JD FEL's will fit on this tractor as well.
Your input is greatly appreciated.
   / Who makes or has plans for FEL - JD 445 #2
The JD 40 fits the 425, 445, and 455. One on eBay now
40 FEL
Thanks for the link, I missed that one. I've also checked out the CAD plans for loaders, I'd just need to get one of my welding neightbors to help me out.
   / Who makes or has plans for FEL - JD 445 #4
If your welding neighbors aren't able to help you out you can have your JD dealer order you a loader from Kwik-way. They make loader kits for the 4x5 series tractors and you can buy them with a separate hydraulic pump to run the loader or without if you wish to have the tractor's pump run the loader. The separate pump is really only necessary if you think you might want to add the Kwik-way backhoe later on.
40 Loaders are few, far between, and usually command a premium when they come up for sale. The last 40 I saw on eBay went for $2500, which is about what a new Kwik-way costs. The KW loader has a lift capacity of ~500lbs. which is about twice the spec'd capacity of the 40 loader.
Kwik-Way
Regardless of which way you go, you MUST add the transaxle relief valve and corresponding free-wheeling lever if you add a FEL to your 445. Failure to do so can result in damage to your hydro.
   / Who makes or has plans for FEL - JD 445 #5
Kwik-Way
2018 Ram 2500 Pickup Truck, VIN # 3C6TR5HT2JG344853 (A44391)
2018 Ram 2500...
2008 UTILITY 53X102 DRY VAN TRAILER (A43004)
2008 UTILITY...
2016 Ford F-350 4x4 Pickup Truck (Diesel), VIN # 1FT8W3BT4GEC38506 (A44391)
2016 Ford F-350...
New/Unused 30ft x 65ft x 15ft Storage Shelter (A44391)
New/Unused 30ft x...
2025 8ft Office Shipping Container (A44571)
2025 8ft Office...
2020 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A44572)
2020 Chevrolet...
