Who's using the latest ETA XTreme Duty 6 way Tractor Scrape Blade?
   / Who's using the latest ETA XTreme Duty 6 way Tractor Scrape Blade? #1
BGigHarbor
GIg Harbor ish
.l5460, bcs 725, 852
That blade has a pin and a nut on the rear angle adjustment to take out play from wear, etc.
The offset is just a pin in a hole, no obvious adjustment on tension.
How well does that offset capability work out in terms of play or movement where it pivots for the offset? (I don't mean the angle adjustment at the rear.)
I suppose a person could always put in a bolt if they really needed.
Thanks, Bill
   / Who's using the latest ETA XTreme Duty 6 way Tractor Scrape Blade? #2
Bill,
The offset and angle adjustments use the same style pins on chains for adjustments and I doubt they will ever need to be replaced with bolts. The large nut holds the blade to frame and regulates that tension.
I see you talked about getting a "custom" rake from ETA in your other thread. Are they putting it on this frame? I talked with Travis when I was looking for a rake and wanted off set but they didn't offer it.
A neat feature would be to offer a rake and blade combo, that uses the same frame. They could do it I'm sure. :thumbsup:
Bill,
I see the nut that adjusts tension on the angle adjustment, but don't see a way to tension the offset adjuster on the rear blade. That is what I as wondering about having some play in over time.
I called and ordered the stuff this morning including the landscape rake and I asked Travis about an offset like their new smaller landscape rake has. He called me back a little later and said Ted said they could make me a version of the bigger landscape rake like I wanted but with the offset adjustment taken from their top rear blade (for extra money of course).
Thus my question about how much play involved with the offset (not angle) adjustment on their current scrape blade as I can't see a nut unless it's below.
Since I want a 7 foot rake to go with my 6 ft wide tractor, I thought an offset could be really handy at times to determine where the windrow was or maybe raking a little farther to the side of one of my roads on the property.
   / Who's using the latest ETA XTreme Duty 6 way Tractor Scrape Blade? #4
The offset pivots on that long pin on the front and appears pretty substantial. (The pin on mine is cross pinned with a cotter pin) Combined with the angle pin it doesn't look like it would be problematic. I think maybe they might have "over sold" the ability to adjust tension on the rear a little. Then again YOU will be the first one to own one so I guess you will have to give us a short and long term report. The pioneers take all the arrows!
You will like the off set. Just be careful you don't forget it's out there and rip the siding off the corner of the barn. :confused3:
I have the 96" Land Pride and bought it because of the off set. My tractor is 90" wide and it was the best bang for the buck without spending crazy money. Well it took three hours with a grinder and Dremel tool to make it function as it should. Not to mention the POS dealer who just dropped it at the end of my drive, knowing it wouldn't fit the QH. It took a big drift pin and small sledge hammer to remove the off set pin, since it was obviously installed with one. Ever dangle an 8 ft rake from your FEL for 1/4 mile?
If you hate someone profusely and want to inflict despair, recommend they buy the Land Pride. My daughter insists ever since the rake was delivered, my grandson has acquired the ability to string multiple four letter words in a single sentence. I say it's just coincidental.....
   / Who's using the latest ETA XTreme Duty 6 way Tractor Scrape Blade? #5
Dave,
I'm surprised your so unhappy with the Landpride rake? Are you thinking about selling it to buy something different?
Bgig,
I was wondering if you ended up deciding on the hydraulic rear blade vs manual. Are you getting hydraulics with this blade from EA?
Piston,
For now I still haven't decided which rear blade but still think I probably want at least hyd angle and ETA doesn't offer that yet.
The reason I am asking about the ETA blade is that they are going to custom build me an ETA landscape rake with the offset portion taken from a ETA xtreme blade because the bigger ETA landscape rake doesn't have offset yet.
I would like hydr angle on the landscape rake too but I don't think it is as critical for me and I really need the rake like yesterday for the new property. Tearing up lots of stuff with the scarifiers on my hrl3578 and it is in piles for acres. So ordered a landscape rake and wicked grapple to get that under control as soon as possible. Once the rains start I probably won't be able to work that area of my property as it is sloped and will be a muddy mess if I try.
I wish ETA had a hydra ready rear blade for angle at least, but that sounds like it is a ways out. My top candidate so far is still the LP. If money was no object and I would use it more than I will, the big rhino looks pretty cool. But after I get the property and roads all under control in a couple years, I won't be able to justify the expense of something like the big rhino.
And a friend has a home brewed hydra angle rear blade I can borrow if I want.
At least that is how I feel now.
My hydra BB will get a ton of use for the next few years so I feel it was money well spent. If the tractor is delivered back out to the new property tomorrow I'll be back out there hard at it.
Again a plug for the FS RR, I understand now why so many people like it. I was raking out piles brush and saplings like crazy with it within minutes of putting it on the bucket.
   / Who's using the latest ETA XTreme Duty 6 way Tractor Scrape Blade? #7
Piston,
I'm also really interested in seeing if they add hydraulic options to their blades, it seems like its certainly getting more and more popular and I'd think it would be an easy addition/option. I'm not in too much of a hurry to purchase a rear blade but as winter gets closer I'm looking more and more. I've been watching for used ones and although a good blade rarely comes up for sale (usually cheap, lightweight ones in my area) I did find one that I'm going to look at this weekend.
That's great they are working with you like that. I currently have a 6' rake and would love the ability to offset it, especially hydraulically.
Ill be interested to see how often you use the landscape rake once you get used to the grapple, I find that I rarely need to put the rake on as the tines of the grapple do quite a nice job raking up debris, I rarely use my rake now although I do still find a need for it on occasion. Another helpful way to use the grapple when land clearing is to back blade with it like you would a bucket. You can get a surprisingly nice finish with the open bottom grapple and a little finesse.
Landpride is my top choice as well. If I remember correctly, it had more adjustability in it than other comparable blades, however it's been a while since I've compared. Something to keep in mind which I find odd, considering the look just about identical, is that you can get a hydraulic gauge wheel option with the LP RBT35 series, but they don't offer it as an option on the 40 series blades. I can't see why since they are very similar but they don't.
It is really hard to justify the additional cost of full hydraulics, but if I cant find a used one ill probably just bite the bullet and buy one. I got a recent quote for an RBT3596 with all 3 hydraulic cylinders, PLUS a hydraulic gauge wheel, for a whopping $4,129. Keep in mind this is from a dealer that is typically high anyways, but still it's a lot of coin, although it would last a lifetime.
It seems the only difference between the 35 and 40 series blades is a heavier frame, the blade thickness is the same although the support on the back of the blade to give it stiffness is a bit thicker. Either way both these blades are PLENTY strong enough for our size tractors, and the 40 series is a bit overkill.
Which Rhino blade were you referring to?
You'll never regret that purchase!
Do you mean the ratchet rake? If so, this is another thing that I'd be interested to hear how much you use it after you get the grapple. Again, I bought one of these during the sale they had and I tried it out a few times on my tractor, but I find that it's not worth the hassle to change out the grapple for the bucket so I can use the RR when the grapple does such a good job on its own. I truly is the "Jack of all trades" implement!
Sorry for the long winded post! :)
   / Who's using the latest ETA XTreme Duty 6 way Tractor Scrape Blade? #8
Bill,
a rake and blade combo :thumbsup: :thumbsup: :thumbsup: That's what I need. With the lack of storage space that I have that would make a lot of sense.
   / Who's using the latest ETA XTreme Duty 6 way Tractor Scrape Blade? #9
Dave,
Two requirements I had were off set and Cat II QH compatibility. Your choices are very limited and I always heard good things about Land Pride. Neither dealer I visited had ever stocked one, let alone actually seen one outside of the catalog. I was actually trying to buy the rake/blade combo but the blade frame was being changed to a 37 series and two calls to the factory and one to the regional rep cleared up nothing on what those changes were.
I was convinced by others on here the blade would be too light and so I ordered just the rake which was the 36 series. When the dealer dropped it off there was no way it was going on the QH. I ended up grinding down an 1/8" off each side of the QH to make it fit. In addition every hole for offset and angle had so much excess material in them, you couldn't insert either adjustment pin, just removing them was a chore. I could see hammer marks on them where the dealer put them in.
Every other implement I own is QH compatible and this is the only one where fit was a problem. It now works, but I seriously doubt I would ever buy Land Pride again. Plus my local Land Pride dealers are clueless.
JOHN DEERE 648R LOT NUMBER 108 (A53084)
JOHN DEERE 648R...
BUSH HOG 7007 LOT NUMBER 111 (A53084)
BUSH HOG 7007 LOT...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50323)
BW RVB3405...
2007 Freightliner M2 106 Ambulance (A51692)
2007 Freightliner...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
A1 MIST SPRAYERS RESOURCES TX3PT LOT NUMBER 85 (A53084)
A1 MIST SPRAYERS...
