vulcancowboy
My wife called me Tuesday to say that the local Ford dealer had finished inspecting her '06 Lincoln Zephyr. While it didn't need anything to pass inspection, the mechanic said since the car has 105K miles on it, we should change the serpentine belt, replace the spark plugs, valve cover gaskets and install a new air filter. Approximate cost? $1,000!
I told her NO WAY! I can do it myself.
So, I did a little research and found that in order to replace the plugs, you have to remove the intake manifold! I did replace the belt, which was not too easy either. I had to jack up the car, remove the right front tire & fender liner to get to the belt.
Seems kinda ridiculous to me that I have to remove a manifold just to change plugs, needless to say, I'm holding off on that job for a little while, at least until I recover from the belt changing exercise.
