Why relays?
   / Why relays? #1
joshuabardwell
Elite Member
Knoxville, TN
Bobcat CT225
I have a kind of dumb question. I'm no stranger to simple electronics, but I'm relatively inexperienced with automotive electronics, and I'm trying to figure out the proper usage of a relay. My understanding is that a relay is used when the current draw of the load is more than the switch that controls the load would be rated to handle. But what's confusing me is, I see switches all over the Internet that are rated to handle 15-20 amps at 12 volts, which is plenty for many applications. So why not just run the hot wire directly through the switch and be done with? And then I look under the hood of my tractors, and there's relays all over the place. So there must be something I'm missing. There must be some reason to use a relay other than that the switch isn't rated to handle the current draw of the load.
The example I'm pondering right now is, I'm thinking about putting a light set on my ROPS. I was thinking, if I wired a relay into the hot wire running to the headlights, then I could control the ROPS-mounted lights with the headlight switch. But wait. Why not just splice into the headlight wire and run my lights directly off that? Assuming, that is, that the headlight wire could handle the current draw.
   / Why relays? #2
relays can allow a shorter path from the battery to the load. for example a set of lights on the front, the battery is located at the front and the lightswitch is at the back. with the switch and no relay, the power has to travel from the battery 5 ft to the switch and then 5ft to the lights. with a relay, the current path is much shorter, say a foot or 2. the lights will be brighter with the shorter path. relays can also be useful in creating a sequence that items are powered or not. say you have multiple lights and want them to come on in a sequence, with a relay that can be done. or another is one set turns OFF when another set turns on.
   / Why relays? #3
Lighter gauge wire in the dash area takes less space too, as well as the reduced cost of the smaller wire.
   / Why relays? #4
The main reason Relays are used is to take the load of resistance off of the switch.
   / Why relays? #5
I'd rather have any switch that I have to touch in an outdoor environment be low current.
   / Why relays? #6
These days there is so much computer control going on, and a micro chip can only handle current in the milliamp range. Therefore, the relay.
   / Why relays? #7
You need to be sure that switch you see is rated at 12 volt DC. DC arcs much more than AC and the switch must be heavier duty. Relays are a good thing.
Kim
   / Why relays?
That's a good point. Just because the switch is rated for so many amps doesn't mean you want those amps hitting you in a failure mode.
Yeah, they definitely are 12 volts. I can't hardly find a 12-volt switch rated for less than 20 amps.
   / Why relays? #9
This is one of my understanding of using relays also in that you can use smaller wire to and from the switch and then the larger waire to the relay and the load.
Here's some information on Relays from the following website Relays This website seems to do a pretty good job of explaining relays.
Two Reasons to Use a Relay:
A relay will allow you to use a small current to control a larger current. Generally, a relay coil has a relatively high resistance and will require only a small electrical current to engage the contacts. Typically, the contacts are rated to carry much more current than it takes to engage the relay. This means that a relay can be used if you need to make/break the circuit path where there is a relatively high current flow and the control circuit can only supply a small amount of current. In your vehicle, the ignition switch cannot pass a significant amount of current without being damaged. You probably also know that the engine starter motor needs significant current to be able to start the engine. Since it would almost instantly destroy the ignition switch if you were to try to power the starter motor with the ignition switch itself, manufacturers use a relay (also known as a solenoid) as a buffer between the ignition switch and the starter motor. In old Ford vehicles, the solenoid was mounted on the fender. On other vehicles, the solenoid was mounted onto the starter. If you ever have to work on the starter, you will see that there is at least one small wire and at least one very large wire. The small wire drives the coil of the solenoid. The larger wire supplies power to the actual starter motor. In this application, the relay/solenoid is used to allow a small current to control a larger current. In car audio, the most common use for the relay is a buffer for the remote output of the head unit. Since the head unit's remote output is limited, the relay allows you to power many more devices than you could with the remote output otherwise.
The second reason to use a relay is to isolate two circuits. If you needed to control a very high voltage circuit with a 12 volt controller, you could use a relay. Since a relay coil is 'generally' isolated from the contacts, you typically have complete isolation between the 'input' and 'output' section of the relay. Of course, the input of the relay is the relay coil and the output would be the contacts.
Here's a couple more websites I came across with some decent information:
Single Pole Double Throw (SPDT), Single Pole Single Throw (SPST) Automotive Relays
Special Applications with SPDT Relays, Diagrams
   / Why relays?
That's really interesting. I hadn't considered that.
   / Why relays? #11
Real life example - I have a '96 Dodge Dakota. From the factory, power to the headlights goes through the switch in the passenger compartment, no relay involved. It's a common upgrade to add a relay and a short power wire, with fuse, from the battery to the headlights. You still use the same light bulb. There's less of a voltage drop in this arrangement so the bulb gets more power. I haven't done it yet (it's on the list), but it's supposed to be a big improvement in the amount of light the bulbs put out. Could you do this without a relay? Yes, but it would involve using bigger gauge wire, even bigger than the short power wire you'd use in the relay arrangement, from the battery to the switch to the lights.
Also, some switches are not easily upgraded to handle the current needed by the devices they control (ie, ignition switch).
Keith
   / Why relays? #12
12v @ 20a is a mere 240 watts, as is 120v @ 2a, so 12v switches must handle a lot of current to control a decent amount of power. A 30w bulb draws 2.5a @ 12v and you'd need the capacity to light a pair or a quad of bright ones. One switch can control several relays, and with a few well-placed diodes different load/relay combos can be grouped to specific switches. (watch the v & a ratings) This can also provide alternate/back-up current paths to relays if a switch fails at the worst time. More to test/maintain too, but one either gets wiring or should find help easy to attain. Swapping relays is a trouble-shooting shortcut ...
   / Why relays?
So, the point is that because the power wire to the headlights is shorter and can be thicker, more power is delivered? Whereas if you had to wire directly to the switch, it would be longer, and would need to be thinner, and you couldn't deliver as much power.
   / Why relays? #15
Joshua, Count me in the same boat as you - to a degree. I get the reasons for relays in many cases. You don't want to run 30a or 50a current through switches as the switches would be very expensive to be rated for that. If you add in that many automotive switches are customized for aesthetics to look nice with the interior, this could get really pricey. On the flip side, relays are hidden and standard - just pick the rating you want - so they are cheap and easy to change if they fail (plus they are less likely to fail by design). Then the short current path some discussed is also a good reason for heavy current draws (shorter wire = less resistance, or allows them to use a smaller wire due to the shorter run to save $$). All that makes sense. But for the little 5-10A loads? Those I just don't get, but they still use relays. Perhaps it just became so routine that they do it out of habit. Dunno.
The other item cited - control a high voltage circuit with low voltage controls is very common but does not apply to automotive applications where everything is 12v. That is a very common use in industrial equipment where you may have a computer controlling 460v/3 phase loads, or even higher current 120V or 220V loads in a house. A forced air furnace or central air conditioned would be a very good example of this at home. The thermostat is typically low voltage 24v but control 25A+ compressor motor starting loads at 220V.
   / Why relays? #16
The amount of current going through the circuit has very little/no affect on how much it will hurt you. Voltage is what matters, most of the time 12v is not enough to break the resistance of your skin. That is why it is nearly impossible to be electricuted by a car. Now the amount of current that flows through "you" does matter. But that is dependent on the resistance of "you" and the voltage of the circuit, not the current in the circuit that is there. I know that this is a terrible explanation but I am not a teacher.
Another reason for relays is that their action is nearly instantaneous, which means much less internal arcing while the switch is being thrown. This is especially important when controlling motors. The contacts also should theoretically last longer in a relay because of this.
   / Why relays?
Upon further thought, I can see that relays would also be very important if your switches were very small--in other words, if you were using DIP switches or had a microcontroller (like an Arduino board) or something like that. These switches have much less current-carrying capacity than full-sized switches.
   / Why relays? #18
Circuit current may not be as important, but the available current if you were to get shocked does have relevance. If the circuit only handles low current (1/10 amp) say, it poses little threat, but the same voltage in a 30 amp circuit has more potential to do harm.
   / Why relays? #19
not really, available current is only limited by your fuse protection. If you have wires ran straight from a battery to a switch (as a lot of people do) there is no limit (short of wires melting open or just the capacity of your battery) to the amount of current that has the potential to go through your body, even if the switch was only powering a little LED light.
   / Why relays? #20
By using relays you can design circuits that would take a very complcated switch to duplicate. One of my favorites is a circuit that won't let you switch off an engine while the lights are still turned on. Turn off the key and remove it, the engine still runs until you turn off the lights, at which time everything shuts down and won't restart without the key. On an old 4x4 I could push a button which would let the engine run without the key, but shut everything down as soon as anyone touched the brakes-great for leaving it running with the heater on while you went in for coffee in an area where someone else might try to drive away.
MORBARK WOOD HOG 3400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
2012 TAKEUCHI TL12 SKID STEER (A60429)
2012 TAKEUCHI TL12...
CAT 289D3 (A58214)
CAT 289D3 (A58214)
CAT CB34 (A60462)
CAT CB34 (A60462)
2015 JOHN DEERE 35G EXCAVATOR (A52707)
2015 JOHN DEERE...
2020 Chevrolet Silverado 1500 (A55315)
2020 Chevrolet...
