Wider front tire suggestions for 1530 (2wd)
   / Wider front tire suggestions for 1530 (2wd) #1
lowandslow1
Graham, WA
John Deere 1530 Diesel
I am looking to replace the three rib 7.50-16 front tires on my JD 1530. I have a FEL on the front. Living in the NW the ground is sloppy (6 months out of the year) and I am looking for a little more floatation, actually a lot more floatation. The rear tires do great, but the fronts make awful ruts... Nothing is off the table: truck tires, skid steer, aircraft, blimp...doesn't matter. Just would like a wider front that doesn't knife into the ground. Would even consider replacing the front rims as well, if that is what it would take. I don't use the draw bar so, a larger diameter front tire would be good as well. Wondering if anyone has put a wide bias ply truck tire on the front and how wide of a tire can you put on a these rims. I'll be using tubes. Thanks.
   / Wider front tire suggestions for 1530 (2wd) #2
You could get some of these used aircraft tires if you decide on no flats GENSCO AIRCRAFT TIRES. Home
   / Wider front tire suggestions for 1530 (2wd) #3
I think we have different rims, but on my 2030 I have 11.00 - 15" front tires. These are tractor tires, nothing special. Not implement/wagon tires
   / Wider front tire suggestions for 1530 (2wd) #4
1530 parts catalog only lists 3 frt wheel sizes although most 6 bolt implement wheels with the correct center dish
JD3002 RIM 1 (6.00-16, 6.50-16 TIRE)
JD3039 WHEEL 1 (7.50-16 TIRE)
JD3047 WHEEL 1 (27/9.5-15 TIRE) will fit.
Cub Cadet Kohler mower 7000 series (A50324)
Cub Cadet Kohler...
2025 CFG Industrial STSD10 (A50123)
2025 CFG...
2001 Club Car Carryall Utility Cart (A51691)
2001 Club Car...
Adams 5T HC Spreader (A53473)
Adams 5T HC...
1264 (A50490)
1264 (A50490)
2019 Ram 1500 4x4 Crew Cab Pickup Truck (A51692)
2019 Ram 1500 4x4...
