Will 16hp pull a 48" deck with a fan-assisted bagger?
   / Will 16hp pull a 48" deck with a fan-assisted bagger? #1
Jack Vines
Bronze Member
I have a CC 2166 with the 16hp Kohler. It came without a deck and I finally found a 48" three-blade deck in mint condition. The deck came with an unmounted belt-driven Model 292 fan assist blower to help move clippings up to the bagger.
The 16hp pulls the 3-blade deck OK in low grass without the blower installed, but I'm concerned adding the blower, especially if grass is high, might be a strain on the little Kohler.
It's unknown what horsepower machine from which the deck came, but most with that 48" are at least 22hp.
Thoughts?
jack vines
   / Will 16hp pull a 48" deck with a fan-assisted bagger? #2
The funny thing is they use to use 16 hp on 48 inch decks years ago. We had a cc106 that had a 42 and a 10 hp K series engine. Now 42 inch is 16-25 hp. Different engines and different hp rating system.
   / Will 16hp pull a 48" deck with a fan-assisted bagger? #3
When Dixon came out the base model had an 8 hp engine on a 42" deck. Premium model had an 11 hp.
Walt Conner
   / Will 16hp pull a 48" deck with a fan-assisted bagger? #4
I have had a 2185 for many years. 18 hp and 48" deck.
Lots of power. I run it as fast as it will go as I have a large rural area.
Optional for my model was the fan assist blower.
If you stick to dry grass I would not expect you to have problems.
Mowing speed and width of cut are two factors you can control to match engine power to load required.
Dave M7040
2015 FORD F-150XL SINGLE CAB TRUCK (A51406)
2015 FORD F-150XL...
2022 Third Coast Reversible Plate Compactor (A51573)
2022 Third Coast...
John Deere 752 4-Star Hay Tedder - Reliable Ground-Driven Tedding Machine (A52128)
John Deere 752...
TRAILER AXLE (A51244)
2015 BMW 3 Sedan (A50324)
2015 BMW 3 Sedan...
NO TITLE - Utility Trailer (A50514)
NO TITLE - Utility...
