Will this work?
   / Will this work? #2
Since lubing the FEL and BH are ongoing maintenance, any grease that is gooey and can be pressed into the fittings will work. Some grease may last longer in front end joints than others, but the grease in the FEL and BH joints gets (or should get) replaced often enough that you do not need the "best" or "most expensive" grease ... you just need to do it often and throughly.
We tend to use whatever gets damaged at the NAPA where my brother works :)
   / Will this work? #4
If you have a Chevron distributor close by, try some Delo Grease. Wheel bearing approved, good on any chassis point of virtually any vehicle. No Chevron guy around?, go to a Mobil distributor. Get some Mobilgrease XHP 222.
Either of these are reasonable in a 10 pack, you're good to go for a long time.
   / Will this work? #5
The Valvoline grease is what I use on all my vehicles and my tractor. It's worked great for me.
   / Will this work? #6
for joints that get greased alot ( or should ).. I use the tsc cheapy 1.90 black molly grease. since I am greasing things each use.. it's not so hard on the wallet at less than 23$ a CASE.
soundguy
Polecat swift 206R (A50322)
Polecat swift 206R...
John Deere 6410 Loader Tractor (A50514)
John Deere 6410...
2020 INTERNATIONAL LT625 SLEEPER (A50854)
2020 INTERNATIONAL...
JOHN DEERE 8410T TRACTOR (A51243)
JOHN DEERE 8410T...
2015 Hamm H7i VR-3 Single Drum Vibratory Soil Compactor (A49346)
2015 Hamm H7i VR-3...
2018 Nissan Murano S SUV (A50324)
2018 Nissan Murano...
