Winter Covering /Tarping of a new tractor
   / Winter Covering /Tarping of a new tractor #31
Some HST's also need the clutch pedal blocked down- our Kubota came with a "specially made" wooden block designed to take the pressure off of the clutch....
Owner's manual should tell you what you need to do to store it safely...
   / Winter Covering /Tarping of a new tractor #32
are you running fluid filled tires? could you let almost all the air out to get you some more clearence and creep into the barn? you could easily gain a foot depending on the tire sidewall.
2-5TH WHEEL PLATES (A58216)
2-5TH WHEEL PLATES...
Giyi Excavator 44" Rake (A57149)
Giyi Excavator 44"...
2016 Ford Escape SUV (A56859)
2016 Ford Escape...
2016 Ford F-150 Crew Cab Pickup Truck (A56858)
2016 Ford F-150...
Ford 8340 (A53317)
Ford 8340 (A53317)
2007 IC Corporation PB105 School Bus (A54814)
2007 IC...
