Wire rope tension
   / Wire rope tension #1
BeezFun
Veteran Member
IL
Kubota B2710
I'm putting up a fabric hoop building, they use wire rope and turnbuckles for diagonal bracing. How tight should the wire rope be? I've looked online and can't find any info, the instructions don't say. I'm thinking it should be like a fan belt, where they tell you how far you should be able to deflect the belt with your finger at the middle of the span. I called the company, they said it should be "snug". I wonder if those are metric snugs or SAE snugs.
   / Wire rope tension #2
Pic of what a hoop building is? It might help in guestimating forces involved. In general, wire rope doesn't stretch much. So snug should mean "don't overtighten it."
   / Wire rope tension
They look like this:
Clearspan
Wire rope stretches a lot, it's considered an elastic member. That's why it's used in applications that need to move around a lot without permanently deforming.
   / Wire rope tension #4
Just tighten opposing ones the same. Don't overcomplicate things.
   / Wire rope tension #5
All the cables should be tightened about the same amount. This would require the purchase of a cable tensiometer. Since the cables will stretch a bit over time you may even want to recheck the tension from time to time. I don't know what they normally go for but I found one on Amazon for $110 used for checking tension on sailboat rigging.
   / Wire rope tension
Perfect, I found this one for $105 on Amazon, just the ticket.
tnx
2025 Wolverine SP-15-84W Skid Steer Snow Pusher (A47484)
2025 Wolverine...
John Deere 4010 (A46443)
John Deere 4010...
2025 Wolverine EX-66-84L Pallet Fork Extensions (A47484)
2025 Wolverine...
2000 SeaDoo Challenger 20ft Jet Boat with Boat Trailer (A44572)
2000 SeaDoo...
2004 TENNANT SENTINEL SWEEPER (A45676)
2004 TENNANT...
2025 Wolverine...
