Wiring chart for JD 3350
/ Wiring chart for JD 3350 #1
Ausmac
Proserpine QLD
Massey Ferguson 188, JD 2130, Fiat 650
Hi. Would anyone possibly have a wiring chart for a 50 series. My 3350 has some swapped wires and I’m looking to get all the dash warning lights working again. My TM doesn’t show the colours or area the sensors are. Thanks.
/ Wiring chart for JD 3350 #2
When you state 50-Series, do specify if it's the Compacts or full size. We have a slew of the 50 Series wiring diagrams for Compacts made by Yanmar.
650
750
850
950
900HC
1050
1250
1450
1650
A split begins at the 1550 as a mix.
There isn't a mess in the 55 Series nor the 70 Series of Compacts until the way higher model numbers.
Deere wasn't too keen on keeping models like this a bit cleaner and has caused confusion over the years.
Sorry. It’s a 3350 which is an agricultural size. Around 105hp I believe. Still haven’t found a wiring schematic yet but did find out for anyone interested that the transmission pressure switch wire is green with white stripe. And yes it took quite some time with a head lamp and multi meter. Also:
The brake light switch to brake lights is black with red stripe.
The horn button to horn is brown with white stripe.
LH indicator wire is green with white stripe.
RH indicator wire is green with black stripe.
Parking lights on mud guards are grey.
As I come across others I hope to keep adding to this post so someone else can maybe benefit from it.
/ Wiring chart for JD 3350 #4
Maybe you still can change the subject title to identify the model you are referring to here. That would help spread your good effort and intentions when others are searching.
Just changed the title. That certainly makes sense with so many models referred to as 50 series. I think they were all the same through 2140, 1650, 3050, 3350, 3650. Among many others I guess.
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
2022 Chevrolet Silverado 2500 HD 4x4 Crew Cab Pickup Truck (A61573)
2022 Chevrolet...
2019 John Deere 4044M (A62177)
2019 John Deere...
2020 Chevrolet Tahoe SUV (A64194)
2020 Chevrolet...
211297 (A62131)
211297 (A62131)
2014 CATERPILLAR 573C FELLER BUNCHER (A64276)
2014 CATERPILLAR...
