Wiring on a 85 2810
   / Wiring on a 85 2810 #1
CountryBoy685
Ford 2810
Hey guys I have a 2810 and I am working on the lights on the fenders. Are the fender lights only supposed to be a flashing lights. If so then can some one lend some insight on rewiring those lights and the 2 on the back of left side fender. I am having to rewire the this part almost from scratch.
Thanks,
Andrew
   / Wiring on a 85 2810 #2
there should be a work light and a red light on that fender u can run one hot wire from the light switch down the left side of the trans up the inside of the fender between the tire and the fender and and make a connections thats has the one wire going into it and three coming out and connectone wire to the red light and one to the work light that should have a togule switch or a push button built into it to turn the light on and off hook the last leg up to a three prong flasher and then make a wire going from one prong to the left and light and the and wire to the right hand light
the lights mounted on top of the fenders might have flashers built in and if thats the case u will not need to get the flasher
it would be a whole lot easier and neatier to get the right wires from nh
these are the part numbers that u need to do it right
D5NN15573B
C5NN13N315A
E1NN13N483AA
D5NN13A449A
(2) 300 GALLON POLY TOTES (A51248)
(2) 300 GALLON...
UNUSED FUTURE QUICK ATTACH MAST W/ 29" FORKS (A51248)
UNUSED FUTURE...
2017 Ford F550 Bucket Truck - Powerstroke Diesel - Auto Trans - 4x4 - Versalift SST40 Boom (A53472)
2017 Ford F550...
UNUSED WOLVERINE TQH-26-02C CLASS II 3 PT HITCH (A51248)
UNUSED WOLVERINE...
Informational Lot - Shipping (A53473)
Informational Lot...
