wobble box for a new holland 469 haybine
   / wobble box for a new holland 469 haybine #1
rusty11
Michigan
99 tc25d jd 3020
Looking for a wobble box for a new holland 469 haybine. All I really need is the metal breacket it self. Or a complete on. The bottom bearing hole is wore out. Thanks
   / wobble box for a new holland 469 haybine #2
Which part do you need? (see attached image). I get all my parts (such as a yoke weld assembly #7) from Flint Ford Tractor. Where are you at ?
#7. I found one at the dealer hear for $342.00. Thought maybe I could find something used a little cheaper.
   / wobble box for a new holland 469 haybine #4
Have you considered making a replacement part for the section tha's worn out? Its just flat steel. If the bearing hole is worn, shove in an insert or collar and grind it down. If the whole piece is shot, weld up a new one.
   / wobble box for a new holland 469 haybine #5
Give frys machinery a call... 570 546 3968, very helpful and very fast
2009 L3 GENERATOR SET (A51222)
2009 L3 GENERATOR...
2012 MACK GU713 DUMP TRUCK (A50459)
2012 MACK GU713...
2015 CHEVROLET CAPRICE POLICE CAR (A51222)
2015 CHEVROLET...
Komatsu PC138 (A50490)
Mack Fire Truck (A50860)
Mack Fire Truck...
2021 Kubota SVL97-2HFC Compact Track Loader (A50657)
2021 Kubota...
