Wood Maxx 8 foot backhoe
   / Wood Maxx 8 foot backhoe #1
5030
Epic Contributor
SE Michigan in the middle of nowhere
Kubota M9000 HDCC3 M9000 HDC
Used the search feature and came up empty handed..
I need some input on a large (at least 8 foot dig depth) 3 point backhoe for either my M9000 0r 105 Kubotas. Both have full cabs and both are Cat 2.
Looked at the Wood Maxx line and they look pretty good but I need some first hand knowledge and/or experience with any brand of large 3 point hoe's. No point in getting a little one, my tractors are both full size.
Planning on some water line trenching and smaller stump removals as well as footer work. I prefer self contained (pump and hydraulic tank) though I have plenty of tractor capacity 21gpm hydraulic flow.
Again, not particular about brand, just want something thats sturdy and basically troublefree.
Thanks..
   / Wood Maxx 8 foot backhoe #2
Thanks..
I don't think you can find anything better than a Bradco. Bradco builds the larger Mahindra backhoes, and they have been bullet proof. As for the Wood Max, I have sold a few of them and I don't think that you can get a better value for the money, but it isn't as much backhoe as the Bradco.
   / Wood Maxx 8 foot backhoe #3
Thanks..
I own a WM 7600 backhoe from WoodMaxx and I love it. I bought it back in Dec. 2014 and have about 25hr on it, it is a much better machine than I thought I could buy for the money. I also own a WM 8H chipper and a tiller from WoodMaxx. With my backhoe I got the 24", 12", and 9" buckets and also got the ripper. and I can tell you it handles them all well. I see they are still giving the free Hydraulic thumb upgrade, my unit has the hydraulic thumb as well. I have removed stumps, trenched 300ft of wire in, and pulled saplings as well as started digging some duck ponds. It has preformed better than I ever expected it would. On a tractor of your size I would go with the WM 8600.
I appreciate the comments. I looked at a Bradco at my dealer that was used (no pump and no subframe). I would have to buy a subframe from Bradco and I'm hearing pro and con on a straight 3 point mount versus a subframe mount. My tractors are both very substantial in the backend castings (CAT II) with full draft control.
I take it I can run a 3 point mount over a sub frame mount. My issue is the sub frame mount compromises my ground clearance and attachment capability. I use both tractors with rakes, square bailers, round bailers, mowers and tedders so many 3 point and PTO driven implements.
This would be ocassional use only, Nothing to rigorous or demanding. Just don't want to break anyhting out back on 45 grand tractors.
   / Wood Maxx 8 foot backhoe #5
My neighbor is selling her JD410B TLB. Great condition! Less than 4K hours. She's also got a cherry JD350 crawler for sale, too.
She needed an idea on what they're worth. I figure her 410B is probably worth $9,000-9,500.
I'd bet a six pack her 410 is less money than you'd pay for a new, sub-frame Wood Maxx backhoe! Had a look on tractorhouse and there's a bunch of low-hour 2WD hoes on there.
Why muck up your good hay tractors with some hoe hardware that might just put those 'Bota's in the dealer's repair shop?
AKfish
   / Wood Maxx 8 foot backhoe #6
Yes, you can, since you have CAT2 3-point.
One of my 10 Prairie Dogs was mounted to a Case 480LL 3PT, which is about 7K pounds.
You must use the fixed strengthened toplink to keep the TPH from floating up, and
I would limit pressure to whatever the hoe maker specifies. Some go to 3K psi, if
made for skidsteers. Bradcos are very stout. I do not know what pressures your
tractors put out.
Why do you want a separate PTO pump/reservoir?
   / Wood Maxx 8 foot backhoe #7
Just for what it's worth. Bradco built the backhoe for my Kubota wheel loader. A good and heavy built unit!
I searched for years for a backhoe for our 6200 JD. Modest HP but a large frame tractor. I was warned by the dealer about a case of someone ripping the 3rd point off such a tractor with a hoe! I kind of gave up on the 3ph hoe idea after that.
I guess since I got the used Kubota wheel loader with the hoe (paid 17K CDN), I have used it a lot for projects and still don't feel that I use it as much as I thought, day to day. But for the time I have used it, I realize how often you have to move the machine when digging and on the R510 you can do that without moving the seat to the forward position. I cannot possibly imagine using a backhoe where you have to disembark in order to move the machine. Reach in a backhoe is everything (I think), digging depth, not so much and this determines how often you have to move. I can totally appreciate the benefits of extendahoe, and would give my eye teeth for that feature.
tractors put out.
I don't need it as an absolute I would prefer it from the hookup standpoint and I don't have to run the tractor but at 1/2 rated speed, I have a 540/1000 pto. I use a 21-6 stub adapter.
AKfish
A acquaitance of mine did just that and I ended up rebusning the hoe which, wasn't cheap. The pin bushings weren't bad but it was a Case Extenda Hoe and the extenda slides had to be replaced and that was a nightmare. Ususally, used equipment at an auction has been in a state of non-maintenance for a while previous to sale so you get someone else's problems and no warranty.
His case also had engine issues and that was an added expense. I don't mind buying used but it has to be a simple piece of equipment, not complex.
43030 (A51691)
43030 (A51691)
New Wolverine 3pt Receiver Hitch (A53002)
New Wolverine 3pt...
1261 (A50490)
1261 (A50490)
2012 UNVERFERTH 15-INCH REAR SPACERS FOR 10 BOLT HUB (A53472)
2012 UNVERFERTH...
6ft LandPride Box Blade (A51573)
6ft LandPride Box...
New/Unused CFG Industrial MX12RX Mini Excavator (A51573)
New/Unused CFG...
