Wood Splitter on Kubota L185
   / Wood Splitter on Kubota L185 #1
ralittlefield
Palermo, Maine
Kubota L185DT
I am considering getting a wood splitter for my Kubota L185. Is this feasible, or will I be disappointed in it's performance?
The second issue is that at this point, I have no connections for hydraulic attachments, but I believe that connections can be added. Is this correct?
   / Wood Splitter on Kubota L185 #2
Generally, tractor hydraulic pumps lack the GPM to happily run a log splitter. Small trailer mounted log splitters run a two circuit parallel pump to gain flow at low pressure, then switch to a single HP circuit to get the work done. Tractor pumps are single stage.
A PTO pump running off the full tractor RPM is the usual bigger hammer solution to this issue.
   / Wood Splitter on Kubota L185 #3
I don't think you'll like the price of adding hydraulic remotes to your tractor or the hydraulic flow you'll get from that tractor. I think you'd have much better luck with a PTO pump. You'll either have to run a large cylinder slowly (more force) or a faster smaller cylinder with less force, but I think you can make something work with 15 HP at the PTO.
   / Wood Splitter on Kubota L185 #4
I think with THAT small of a tractor, you WILL be disappointed with the performance of the splitter, UNLESS you just want something to mess around with and don't plan to split much wood.
SR
2014 Ford Explorer AWD SUV (A50324)
2014 Ford Explorer...
2017 Ford F-250 4x4 Knapheide Service Truck (A50323)
2017 Ford F-250...
2021 FREIGHTLINER 126 SLEEPER TRUCK (A51222)
2021 FREIGHTLINER...
2006 Chevy Trailblazer (A47384)
2006 Chevy...
2012 Case IH Patriot 3330 Self Propelled Sprayer (A50657)
2012 Case IH...
Pickup Instructions (A47384)
Pickup...
