Boondox
Elite Member
- Joined
- Apr 6, 2000
- Messages
- 3,871
- Location
- Craftsbury Common, Vermont
- Tractor
- Deere 4044R cab, Kubota KX-121-3S
I spent all day digging out the contents of my storage shed out in the meadow that collapsed under the weight of the snow. Rescued most everything and transferred it to the garage or the hay storage shed. But a cross member came down right on the operator station of my Woods backhoe, the one I'm trading on the new tractor next week. I noticed the right hand control lever was at an extreme angle from the weight of the roof, and though it popped back into the neutral position as I lifted the debris off it there was no resistance when I put it in the curl position. Sure enough, when I backed Clementine into position and connected the hydraulics, the BH bucket would not curl. The bucket cylinder retracted just fine, but would not contract. No leaks, all the hoses look good, so I figured the linkage probably got damaged. With luck, it might have just popped loose.
But what will I see under the plastic cover, and what are some troubleshooting steps I could use to find the problem?
TIA, Pete
TIA, Pete
