Backhoe Woods Backhoe
   / Woods Backhoe #1
a05883
East Central Wisconsin
Kioti NX 5010, Bobcat ct230
I am looking at buying a woods bh80x backhoe for my tractor. I was told I need a hose kit to connect to tractor. My question is since I have a set of rear remotes can't I just hook it up to them?
   / Woods Backhoe #2
Yes you can. Mine is hooked up to port A and return thru my oil fill tube.Yours would be the same..
   / Woods Backhoe #3
I believe Woods would like to sell you a very specific hose kit, precisely the CORRECT length for hooking up. And a little to short when you can't easily maneuver your tractor to it after the BH has "slipped" a little from where you dropped it. I could have gladly used an extra 6 inches on each hose on my BH70X.
   / Woods Backhoe
I believe Woods would like to sell you a very specific hose kit, precisely the CORRECT length for hooking up. And a little to short when you can't easily maneuver your tractor to it after the BH has "slipped" a little from where you dropped it. I could have gladly used an extra 6 inches on each hose or my BH70X.
Does it seem reasonable that the kit would cost $290 if it only was two hoses?
   / Woods Backhoe #5
Well, I wouldn't be surprised at that price. Ever blown a hose and go to a hydraulic shop and have a new one made?? When I installed my BH-80X I just had a local shop make me two hoses for my backhoe loop...... it was around two hundred dollars for the pair of hoses. That was several years ago.
   / Woods Backhoe
Thanks for the responses.
One more question. I am trying to decide between a 7 qnd 8 foot backhoe. Just wondering why you chose the hoe you did, and would you buy the same if you had to do it over again?
   / Woods Backhoe #8
$35.00 can get you a hand made hose 4foot long at the dealer here. Sure are proud of their hoses.
   / Woods Backhoe #9
You need to let us know more about your tractor, make, model, hydraulic GPM rating, does it have a necessary FEL?
A starting criteria for you is to go online to the Woods site and research which BH model offers a subframe specifically designed for your tractor. That will tell you what Woods would recommend.
One nice feature now being offered by Woods on the BH80-X is an optional factory installed hydraulic thumb.
I have the BH90-X with hydraulic thumb and 4-PT subframe on my NH TC-40.
:welcome:
2022 Case IH Steiger 470HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
2013 Ford F-550 Ambulance (A50323)
2013 Ford F-550...
2004 CATERPILLAR 963C CRAWLER LOADER (A51242)
2004 CATERPILLAR...
Ih 490 Disk (A50514)
Toro Z Master Mower (A50324)
Toro Z Master...
2004 Sterling L8500 4,000 Gallon T/A Water Truck (A50323)
2004 Sterling...
