Woods Dixie Cutter MD160 hp requirements?
   / Woods Dixie Cutter MD160 hp requirements? #1
amg280
Central NY
2011 Kubota B3000
Hello. I cant seem to find the spec sheet on the above rotary mower. Is it too much for my BX2660? I believe I have 19pto HP or something of the like
   / Woods Dixie Cutter MD160 hp requirements? #2
I found some pic's of the MD160 mower on the net, those are nice looking mowers but most Woods equipment usually is. I think the rule of thumb is 5 PTO hp per ft of mower so with only 19 PTO hp on your BX that would be pushing it imho. I don't know the weight of the MD160 but you would probably have to add some weight on the front. I suppose if you only need it for light pasture mowing, it would work ok on your BX but for real heavy brushcutting, it might tend to stall or bog the motor down most of the time forcing you to go pretty slow.
For years I ran a JD750 which had 19PTO hp and 4ft Landpride (540lbs). That combo worked great and only in really heavy stuff would it bog the motor down. I was told that size tractor would run a 5ft mower but I never did try it myself. If you can get the MD160for a good price, you might try it and see how it works out. If you don't like it, you probably would be able to sell it and get your money back out of it.
Toro Zero Turn Mower (A50324)
Toro Zero Turn...
2020 PETERBILT 337 BOX TRUCK (A51222)
2020 PETERBILT 337...
2018 Bobcat T590 Two Speed Compact Track Loader Skid Steer (A50322)
2018 Bobcat T590...
2013 JOHN DEERE 470G LC EXCAVATOR (A51242)
2013 JOHN DEERE...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2017 FREIGHTLINER...
PICKUP TIRE CHAINS (A50854)
PICKUP TIRE CHAINS...
