Woods MD160 Dixie Cutter Rotary Cutter - How do I remove the tailwheel?
   / Woods MD160 Dixie Cutter Rotary Cutter - How do I remove the tailwheel? #1
Herman126
Poplarville, MS
Massey Ferguson 231
Hello,
I have a Woods MD160 Dixie Cutter Rotary Cutter - I am trying to take off the tailwheel to replace it. I managed to get the outer nut off. I thought all I had to do then was slide the bolt/wheel out the other side. I have used an ax and a hammerand knocked on the bolt to try to get it to slide out, but to no avail. Any suggestions? Thanks!
   / Woods MD160 Dixie Cutter Rotary Cutter - How do I remove the tailwheel? #2
On the side you took the nut off there's another nut just inside the yoke still on the bolt. This nut is the preload for the bearings and have to be removed by holding it and turning the bolt out. Hope this is clear enough to follow.
2018 Ford f-150 (A50323)
2018 Ford f-150...
2014 UTILITY 53X102 DRY VAN TRAILER (A52141)
2014 UTILITY...
2006 Komatsu PC400LC Hydraulic Excavator (A50322)
2006 Komatsu...
2010 Chrysler Town and Country Touring Van (A50324)
2010 Chrysler Town...
1997 Cat 953C Crawler Loader (RIDE AND DRIVE) (A50774)
1997 Cat 953C...
