Woods RDC54 Finish Mower for Cat1?
   / Woods RDC54 Finish Mower for Cat1? #1
RunninOnEmpty
Bronze Member
Kioti CK20S
I'm going to check out a pre-owned Woods RDC54 finish mower this weekend. My tractor is a Cat1. & the Woods RDC54 is a "Limited Cat1". Will I have a problem with fitment?
Also, what should I look for when checking the mower? Should I check gear oil on site?
Other than hooking to a tractor (not sure if they have one to try) is there a way to tell all (gearbox, belt, blades) is OK?
   / Woods RDC54 Finish Mower for Cat1? #2
I think it will fit fine. I have a Woods stone rake that was purchased for my BX 2200-it fits fine on my B 2620. I'd check the gearbox oil, look at the belts for wear or shiny spots, and look at the blades for any chunks missing-should show you if it has been abused.
Good luck.
Will
   / Woods RDC54 Finish Mower for Cat1? #3
Check the gearbox oil. Also take something with you to use as a dipstick. I recently bought a used cutter. The seller hooked it up to a tractor and it purred like a kitten. When I got it home I found that the gearbox was BONE DRY.
I would also suggest taking a quart with you. If the gearbox is dry or really low. Add the oil and you'll find out if the lower seal is good (or not....)
I would also check the u-joints on the PTO shaft for play. They'll run you about $35 each to replace.
2024 Kubota RTV-X (A51573)
2024 Kubota RTV-X...
Polaris Sportsman 335 4x4 ATV (A51573)
Polaris Sportsman...
Chevrolet Silverado 1500 Crew Cab Pickup Truck (A52377)
Chevrolet...
2007 Chevrolet Impala Sedan (A51694)
2007 Chevrolet...
2020 John Deere XUV 835M Gator 4x4 Utility Cart (A51691)
2020 John Deere...
2015 INTERNATIONAL 4300 26FT BOX TRUCK (A52576)
2015 INTERNATIONAL...
