Took a quick video today. I will try to get a better one another day.
Woods TSG50 Stump Grinder - YouTube
Thanks for sharing. I'm thinking about getting TSG50 but the bouncing concerns me. It's almost like the frame is not rigid enough. Another TBN member posted about this recently. Has it been a problem for you?
NYTZ22DA,
I've taken it back to my dealer. I expect Woods to honor their warrany and make it functional.
Here is a link to a vid of my joints. If yours act like this, I suspect you'll be very frustrated in a few more hours of use (I hope thats not the case :thumbdown. Shimming the gaps will help, but if pin OD/clevis ID mismatches are significant, I think its a challenge to fix without custom parts (my case in particular).
The joints must be tight side to side and with minimal slop around the OD of the pin to form a ridgid frame for the stump grinder. From discussions with other users, it's clear all TSG50's don't have joints like this.
A side effect of the chatter I expereinced is it dulled the teeth on the outer rim of the wheel in about 20 hours behind the tractor to the point they needed rotation. I don't grind much below grade (~1in) and don't have rocks.
I'm curious to hear how your joints compare to mine.
Matt
