Work Light Reco?
/ Work Light Reco? #1
Gio
Nebraska
Massey Ferguson gc2400
I would like to install some type of additional light source for my Massey GC2400. Something on the Rops that I can point fwd or reverse. I will be spending many cold dark morning pushing snow and I don't think my current lights will do.
Is there an EASY to install system that you would recomend?
/ Work Light Reco? #2
I installed work lights similiar to what you want. I took my power from the fuse block and ran it to a seperate switch on the control panel. From there use 1/4 " wire loom plastic tube to feed up through the frame. Try not to make any mid joint splices , just go to the first light then to the next.Be careful not to chaff any wires use extra rubber tubing when going through pinch points. The advantage with seperate switched lights is you can leave the lights on with the tractor not running ( I know not for ever )
Craig Clayton
/ Work Light Reco?
Thanks Craig. I am going to give it a go next week. Before the snow....
/ Work Light Reco? #4
Is there a LED work light made? I light the idea of a durable work light. My fenders vibrate terribly when I idle the engine down about 600-800 rpms and the old rear work lights just kind fell out and I'd like to put a lite in one of those round rubber gromet things that look like they'd hold up to the vibration the little 3 cyl. diesel put out. I don't see well and no lites don't help. bjr
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2014 Lincoln MKS Sedan (A61574)
2014 Lincoln MKS...
CLARK FORKLIFT (A63291)
CLARK FORKLIFT...
2021 CATERPILLAR 730 OFF ROAD DUMP TRUCK (A62129)
2021 CATERPILLAR...
2025 Stump Grinder Hydraulic Mini Excavator Attachment (A61572)
2025 Stump Grinder...
Misc. Tires (A61573)
