Working on 8N
   / Working on 8N #1
vegaome
New Martinsville, WV
1970 MF-135 and 1951 Ford 8N
Howdy Folks,
My 1951 8N won't start and I could use some advice. Its a 6 volt, positive ground, side mount distributor. The motor turns over and I have 6.2 volts all the way to the top of the coil but not to spark plugs. I took the distributor cap off and dust seal and watched the points and there was no spark.
I cleaned the points with a piece of filter box and got a spark at the points a couple times but then saw it sparking/arching under the plate the points are mounted to. So I pulled the condenser points and plate to see if the was something wrong down there. It was dirty so I cleaned it with break cleaner and lubed with blaster. I do have a new set of points handy and will put them in and see what happens.
I know I should get a manual and I will but I just wanted to ask.
Is the points gap .025 correct?
What is the proper lube for the advance weights under the plate?
Thanks and have a good evening.
v/r
Mike
   / Working on 8N
Sorry, duplicate post. I can't figure out how to delete it. Moderator, please delete.
2015 CAT 573c Fellerbuncher Cutter (A48836)
2015 CAT 573c...
UPDATED INTERNET BUYER'S PREMIUM TERMS (A50775)
UPDATED INTERNET...
1968 John Deere 4020 with 7ft Mower (A51039)
1968 John Deere...
2019 Allmand Light tower (A49461)
2019 Allmand Light...
1274 (A50490)
1274 (A50490)
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A51039)
Neckover GL24-2-7K...
