Workmaster 60 regen cycle questions
   / Workmaster 60 regen cycle questions #1
OFarrell
Bronze Member
NH Workmaster 60
Anyone have the procedure on how to run a regen cycle for a 2018 Workmaster 60? Does it automatically turn off when it's done or do I have to cycle through the menu to shut it off. What rpm is the tractor supposed to run at?
   / Workmaster 60 regen cycle questions #2
Typically unit should regen every 50 hours if you are working tractor above 2k rpm. If not you will see flashing ! Symbol in yellow followed by the regen symbol where the tractor will drop in regen Mode. Rpms kick up to 2.5k and the regen will happen when tractor reaches correct temperature. The cycle could last for 10 to 40 minutes or more depending on how full the canister is with soot. If you think you need to run a manual cycle yourself put tractor in neutral and apply parking brake in a safe place. Hold down regen button for 3 seconds and unit will regen once temperature light regen light is on then RPMs will rise to 2-2.5k rpms and unit will continue cycle until all soot is burned out. That is how it should work based on my prior experiences. Others have noted malfunctions where as the tractor never finishes regen I have not had that issue.
Tye 4 Shank Taratill (A50514)
Tye 4 Shank...
John Deere 8430 Track Tractor (A50514)
John Deere 8430...
1996 COUNTRY COACH INTRIGUE 40FT RV (A51222)
1996 COUNTRY COACH...
2003 MACK RD6885S T/A DUMP TRUCK (A51406)
2003 MACK RD6885S...
(INOP) CATERPILLAR 259D SKID STEER (A50459)
(INOP) CATERPILLAR...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
