Workmaster steering stops
   / Workmaster steering stops #1
Morroder
Bronze Member
Missouri
Boomer3040
Just traded for a new WM 65 and love it except for turning radius. Has anyone taken the bolts out of stop adjustment to get it to turn sharper?
Salesman mentioned it but it was one of those things that only owner could do. Like disabling safety switches
I took the stops off, lifted front wheels, turned wheel both ways and checked clearance by pivoting axle. There appears to be plenty of cylinder travel to short each sides stop by at least a half each and reduce turn radius a lot.
Only think that gives me pause is the gearing and linkage for the front wheel assist. Worried it may wear or bind
There must be a reason the company set stops as they did.
Any thoughts?
   / Workmaster steering stops #3
Hey I came across your thread. How did you remove the steering stops, and have you had any issues after removing them?
Mine had bolts with a spacer. Took bolts out and reduced spacer. I reduced about half the amount I could have with no issues so far
1000000 (A47477)
1000000 (A47477)
2016 ISUZU NPRXD 14' BOX TRUCK (A60430)
2016 ISUZU NPRXD...
2019 MACK PINNACLE (A55745)
2019 MACK PINNACLE...
2023 John Deere 333G for Parts (A56438)
2023 John Deere...
2005 Kubota L3130 (A60462)
2005 Kubota L3130...
2025 CFG Industrial NT20-CZ Mini Excavator (A59228)
2025 CFG...
