would this work?
   / would this work? #1
dirt clod
panama city and altha florida
Kubota L3300, m5700, case 580se
Surplus Center Item Detail
How well would this work to divert curl function to use for grapple and to use other two diverter sections to divert curl for top and tilt?
This would take the place of needing rear remotes and allow for grapple use?
   / would this work? #2
It should work just fine.
   / would this work?
Thanks for the reply
"Check valve in "A" port in the third circuit" What does this do?
   / would this work? #5
Not real sure on that one, but if you call them they have a very knowledgeable staff that possibly can answer that question.
   / would this work? #6
You would have to find out what that circuit does on a Cat skid steer. If you don't want it, just remove the valve, remove the guts from it, and put the valve back in.
   / would this work?
Thanks for the replies. Should be able to control bucket curl, grapple, top and tilt by useing this diverter and the curl function on the FEL control. This is cheaper than the greason diverter valve others are useing. Am I missing something or is this not a better idea than the greason?
   / would this work? #8
Don't know for certain but my take on that valve is #1 elec on switch & full flow to drive a motor, #2 close grapple , #3 is retract grapple. One or the other functons.
If each valve is 2 way it would do what you intend.
   / would this work?
"Allows one directional control valve to control three separate circuits."
a directional control I would think would go two ways.
One valve is setup with a restrictor to control flow for a grapple, nice plus.
When I find something that is cheap AND better, I think I'm missing something. I don't find out what it is I'm missing until I buy :eek: .
This does look like it will work though.
John Deere (A50322)
John Deere (A50322)
2015 Nissan Frontier S Crew Cab Pickup Truck (A50323)
2015 Nissan...
1265 (A50490)
1265 (A50490)
Land Honor Skid Steer 3 pt Adapter (A50515)
Land Honor Skid...
2015 Kia Forte Sedan (A50324)
2015 Kia Forte...
43016 (A51691)
43016 (A51691)
