Wt of 3 point spray full of water??
   / Wt of 3 point spray full of water?? #1
pharmvet
Platinum Member
North East TX
Ford 7710 II FWA, NH TB110 FWA w/ NH 46LB loader, JD 5303 2wd w/ loader
Weight of 3 point sprayer full of water??
I have a new 200 gallon 3pt. Wylie sprayer. I will be using it behint a 7710 and a TB110. I figure full it will weigh 1800 or 1900 lbs (water and machine itself) Will my tractors handle this wt. without problems?
   / Wt of 3 point spray full of water?? #2
Depending on your gound contours you might need front counter weights but you should be fine!
Art, you nailed it. Ive put 2 days in with my sprayer. Tractor handles it ok but is a bit light in the front. Wts would help. Im going to try to have some next season. thanks
   / Wt of 3 point spray full of water?? #4
Depending on what you are running over, another good option is to get your front tires filled with foam. It's like night and day for both of my tractors. I just wish I had done it sooner.
Eddie
   / Wt of 3 point spray full of water?? #6
The Ford 7110 and NH tb110 are good sized tractors. (86+ pto hp) You should have no issues with only 200 gallon sprayer on the back. Your lift capacity for both is much much higher and you have plenty of front end weight. Your JD 5303 should also be ok unless you have some steep terrain.
PENDING SELLER CONFIRMATIONS (A53426)
PENDING SELLER...
New/Unused Mower King 48in Quick Attach Trencher (A51573)
New/Unused Mower...
1/4 '' Wolverine Universal Quick Attach Mount Plate (A51573)
1/4 '' Wolverine...
2023 John Deere RD40F Draper Head (A53342)
2023 John Deere...
UNUSED JCT HYD AUGER (A51248)
UNUSED JCT HYD...
