x320 jd mower deck - my screwup
/ x320 jd mower deck - my screwup #1
hoddykubody
Bronze Member
3520 jd
I made the mistake of removing the mower deck on my x320 without lowering the deck adjustment . Upon installing the deck I cannot get the deck up by lifting with block of wood and prying up . I have the mower depth setting at 3and 1/2 " now . Is there a way to lower the deck adjustment with no weight bearing on the rear arms . By that I mean with the deck off can I lower the deck adjustment without damaging the mechanism. If I remember right dealer said to only make adjustments when the deck is locked up . Any help fellas? I know late nights in the shop .
/ x320 jd mower deck - my screwup #2
i believe the manual will confirm this, but it should be ok to turn your mower height dial to
the low setting, then release the foot pedal. after the pedal is released, pull back against the
spring tension and use the locking handle to hold it back. this should put the arms down with
no upward pressure.
Thanks Dutch that's exactly what I did after rethinking the kabosh. Deck removed cleaned removed , sharpened blades, painted the wear spots, neverseized the guage wheels - no zerk - and installed . Thanks again
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
CFG Industrail MX15RX (A53317)
CFG Industrail...
UNUSED SDLANCH SDLWC WOOD CHIPPER (A60432)
UNUSED SDLANCH...
2018 Claas Volto 900 (A53317)
2018 Claas Volto...
2018 Deere 323E (A53317)
2018 Deere 323E...
2017 Subaru Impreza AWD Hatchback (A59231)
2017 Subaru...
